Some basic torch advice
/ Some basic torch advice #1
Little Red Tractor
Platinum Member
Gloversville NY
Kubota 2301
After thinking it would be a good idea, I finally have put a set of torches together, buying pieces by way of FB Marketplace and Craigs List. Once I get them all assembled, I need to get back into the groove--it's been about 35 years since I've had my hands on a torch, let alone set the regulators.
What's the general thought on pressures for cutting and for welding?
/ Some basic torch advice #2
I run 7-10 on acetylene and 55-60 on oxy. Ain’t got a clue on welding with torches. Never done that.
/ Some basic torch advice #4
On a welding forum, there is a LOT of talk that acetylene is not available right now,,
Blown up plants, tanks unavailable,, etc,,
You may need to learn propane-oxygen,,,,,,,,,, and braze the parts together.
At least propane is great for cutting,,
Let us know if you get some gas,,, (y),,,,,,,,,, No not from chili!! :eek:
Thanks for that. In my collection, the two acetylene tanks both are supposed to be at least partially filled. With my current usage plan, and my current age, that could be a lifetime supply :). I hope I outast the gas...and the gas outlasts any shortage.
/ Some basic torch advice #6
I find this a really good reference for tip sizes and pressures combinations...
It can be found online or at most welding supplies...
And if availability of acetylene is a issue may be propane or propylene could be alternative....
/ Some basic torch advice #9
Never lay down acetylene tanks when using them. Try gas and O2 as low as you can and increase from there. I usually start with 3lbs gas 25lbs. O2 I also prefer smaller tips. Remember it's not a gas axe. If you see and orange/red flame at the tip... the set up is wrong.
Check valves (mentioned earlier by another poster) very important
Good tip cleaners
Soap stone
Pig skin gloves (tig gloves)
I prefer a tinted face shield (#4), welders hat and clear tight fitting fog proof glasses
Long pants over high top leather shoes when cutting. Learned this the hard way
Welders apron or sleeves, I prefer the apron
FR long sleeve ***** or HD cotton. Avoid exposed skin, believe me hot sparks and metal will find it.
/ Some basic torch advice #10
Sberry,in case you didn't already know,it really chaff's my hinny that I can't do that but you can. :cautious:
/ Some basic torch advice #11
Heck…even mig gas and cylinders are hard to find right now.
/ Some basic torch advice #12
Were inert gases and oxygen not used for other things besides cutting & welding,hobbiests wouldn't be able to buy them. As it stand's acetylene get's more expensive with each passing day.
Thanks for all the advice so far. I got the set together this afternoon when I had a few minutes and the garage was reasonably warm.
I found the gauges largely inoperative. I replaced the oxygen set as I'd been given a new set. The ox gauge tells me I've got about 1400 pounds of pressure in the tank...should mean it's reasonably full, right?
The acetylene bottoms out at 100 pounds but pops up to about 400 when I turn the tank on. I'm guessing that's pretty decent for that tank???
I bought all the stuff used. I'm hoping I did OK on the tanks, as long as they're reasonably full.
Once again, any and all information appreciated.
/ Some basic torch advice #16
Another caution is to never get oil or petroleum products on the oxygen gauge or hose fittings. It will cause a violent reaction.
/ Some basic torch advice #17
as mentioned, don't transport or lie tanks horizontally, & if you have to, allow 12hrs or more for the acetone to settle in the acetylene tank. otherwise, apparently can do damage to reg. assume you have anti flashback valves on both lines as well regards
/ Some basic torch advice #19
One thing I don't do is exchange bottles. I own all of mine including the shielding gas bottles. and I have them filled and returned to me. Airgas has a compressor station south of me so I have a pretty convenient place to get them filled. When transporting them, I lay all of them down flat in the bed of the truck but I stand them up and let them sit for a day or 2 before using them, especially the acetylene because it's dissolved inside the bottle in a substrate. My bottles all have my company name on them as well.
John Deere 6359DF (A64912)
John Deere 6359DF...
2020 Gooseneck 6'x16' Livestock Trailer (A64912)
2020 Gooseneck...
2006 W-W TRAILER 20' T/A ENCLOSED TRAILER (A67714)
2006 W-W TRAILER...
2023 TAKEUCHI TL10V2 SKID STEER (A65056)
2023 TAKEUCHI...
1024 (A63111)
1024 (A63111)
2023 Monroe-Tufline DS1120T 10ft. Hydraulic Box Scraper Tractor Attachment (A66734)
2023...
