Solar Battery tender for dump trailer
   / Solar Battery tender for dump trailer #2
I would opt for the 15 watt panel.
At 830 milliamps you'll have that added reserve for those cloudy days.
   / Solar Battery tender for dump trailer #3
I’d like to do this also, that is the panel I use for my genny. Works well.
On the trailer how would you mount it so it wasn’t likely to succumb to breakage?
I was just gonna mount it on top the pump box. Maybe make a cover on a hinge so when trailer parked and not in use you just flip it up to charge
   / Solar Battery tender for dump trailer #5
   / Solar Battery tender for dump trailer #6
Deltran is high quality products.
   / Solar Battery tender for dump trailer #7
   / Solar Battery tender for dump trailer #8
Also to orient it to teh prevailing sunlight regardless where it was parked/stored.
   / Solar Battery tender for dump trailer #9
Mine is mounted flat facing up on the tongue box. I got a 20 watt panel which is overkill. On most RVs & trailers it's way easier & cheaper to go overkill on panels & just flat mount them. Sun tracking systems, or even just making a mount so you can angle them is complex & expensive. At least compared to a fixed mount.
NEW Fork Extensions (A53002)
NEW Fork...
Selco V5-HD Vertical Hydraulic Baler (A51691)
Selco V5-HD...
2004 PROCO 130 BBL VACUUM TANK TRAILER (A52472)
2004 PROCO 130 BBL...
BOBCAT 260 WELDER/GENERATOR (A52472)
BOBCAT 260...
2022 FORD F-250 SUPER DUTY (A52472)
2022 FORD F-250...
2013 John Deere Gator 825E (A51573)
2013 John Deere...
