Solar battery charger
   / Solar battery charger #2
I guess it depends on what you plan to do with it. You can buy solar panels for $1 a watt - this one is only 5 watts.
   / Solar battery charger #3
I have an electric fencer that uses a solar panel to charge the battery. It works great. Never have to go to the far end of the property - exchange the battery & recharge the first one. Its been on the fence 41/2 years now. I do have all the controls in a weather tight Tupperware tub. Only the solar panel is outside. My only thought is - if you keep your tractor under cover - is the wiring long enough so you can get the solar panel out in the sunshine. Otherwise, I think this is a good idea and sure will extend the life of a battery. I've used Battery Minder chargers - they are good units.
They said they have a 20 foot cord on the solar panel.
Yes it will mainly be to charge the tractor battery.
   / Solar battery charger #6
This set up is a combination of a charger, de-sulphantor, and solar panel.
You can buy larger panels at a dollar a watt (or less), but the smaller ones still run in the several buck/watt range.
Also this one says it supports 2 batteries. Reviews were good on it.
   / Solar battery charger #9
This one is $24 a watt. Expensive de-sulphantor.
   / Solar battery charger #10
I guess it depends on what you plan to do with it. You can buy solar kit for $1 a watt - this one is only 5 watts.
Is that really possible? Can you tell the best place to get these panels?
2022 Heli Forklift (A51573)
2022 Heli Forklift...
2010 Hyundai Elantra Touring Sedan (A51694)
2010 Hyundai...
2014 TROXELL 130BBL VACUUM TRAILER (A52472)
2014 TROXELL...
2019 HYUNDAI HX300L EXCAVATOR (A51246)
2019 HYUNDAI...
TOOLBOX (A52472)
TOOLBOX (A52472)
2025 New/Unused Wolverine Pallet Fork Extensions (A51573)
2025 New/Unused...
