Solar battery charger
/ Solar battery charger #2
I guess it depends on what you plan to do with it. You can buy solar panels for $1 a watt - this one is only 5 watts.
/ Solar battery charger #3
I have an electric fencer that uses a solar panel to charge the battery. It works great. Never have to go to the far end of the property - exchange the battery & recharge the first one. Its been on the fence 41/2 years now. I do have all the controls in a weather tight Tupperware tub. Only the solar panel is outside. My only thought is - if you keep your tractor under cover - is the wiring long enough so you can get the solar panel out in the sunshine. Otherwise, I think this is a good idea and sure will extend the life of a battery. I've used Battery Minder chargers - they are good units.
/ Solar battery charger #6
This set up is a combination of a charger, de-sulphantor, and solar panel.
You can buy larger panels at a dollar a watt (or less), but the smaller ones still run in the several buck/watt range.
Also this one says it supports 2 batteries. Reviews were good on it.
/ Solar battery charger #9
This one is $24 a watt. Expensive de-sulphantor.
/ Solar battery charger #11
i have a 15 watt panel with charge controller, i had it mounted to a camper. it would not provide enough power to keep battery charged enough to run a lp detector and electric ignitor for a propane fridge for 5 days. it think that having the right angel toward sun and your geography can greatly affect its performance.
2016 CATERPILLAR 299D2 SKID STEER (A63276)
2016 CATERPILLAR...
2018 JOHN DEERE 650K LGP CRAWLER DOZER (A65053)
2018 JOHN DEERE...
KUBOTA SVL97-2 SKID STEER (A64279)
KUBOTA SVL97-2...
Pemberton Inc 416469 Hydraulic Dual Cylinder Grapple Bucket (A64194)
Pemberton Inc...
2005 Peterbilt 379 Ext. Day Cab (A62613)
2005 Peterbilt 379...
Mahindra Emax 22S Loader Tractor (A66285)
Mahindra Emax 22S...
