So whats this
/ So whats this #1
escavader
western maine
bx-23 ,
Found it in the old sawmill building i bought .not a spec of rust and a magnet wont stick to it .someone had been using as a drift .very very heavy for its size, lead?stainless?
/ So whats this
Forgot pic
/ So whats this #3
300 series stainless would be my guess. Lead doesn't work well for drifting, and stainless flows well when whacked hard.
/ So whats this
All my drifts are brass wouldnt this damage what your beating it on ?
/ So whats this #5
Depends on what the goal is. :)
Driving a big seized pin out of a gear - do you want the pin out, or do you worry about marring the end of it?
/ So whats this #6
I'm with Jim looks like stainless.
/ So whats this #7
Lead would mush out on top and bottom way more when hit over the years. We have many lead hammers, but no lead punches where I work.
/ So whats this #8
Also, if it was lead, you could take a sharp item and scratch it pretty easily. Give it a try.
/ So whats this #9
Probably a mix of stuff, stainless and maybe nickel.
/ So whats this #11
If lead you would be able to shave a small piece off one of the burls.
/ So whats this #14
Take a "slice" off one end and see what it looks like inside,
it looks like it could use a slice, before chunks of it go flying in your face.
/ So whats this
Take a "slice" off one end and see what it looks like inside, it looks like it could use a slice, before chunks of it go flying in your face.
Your right on that one it could I'll see if my bandsaw will cut it
/ So whats this
I cut one end heres a pic
/ So whats this
Was it easy to cut? Or was it hard like Ni-Hard steel. I tend to think it is a wedge for splitting logs and was later used as a punch.
Well its definitely hard but my bandsaw cut it not fast
2009 PALFINGER 11 FT SERVICE BODY (A62613)
2009 PALFINGER 11...
2012 MACK GU713 DUMP TRUCK (A63276)
2012 MACK GU713...
2011 Terra Riser 300D-SA Fire Plow Attachment (A61572)
2011 Terra Riser...
John Deere 635F 35' HydraFlex Grain Head (A64119)
John Deere 635F...
2019 KENWORTH T680 T/A 6X4 SLEEPER TRUCK TRACTOR (A59910)
2019 KENWORTH T680...
2019 JCB 2TS-7T High Flow Compact Track Loader Skid Steer (A61572)
2019 JCB 2TS-7T...
