So whats this
/ So whats this #1
escavader
western maine
bx-23 ,
Found it in the old sawmill building i bought .not a spec of rust and a magnet wont stick to it .someone had been using as a drift .very very heavy for its size, lead?stainless?
/ So whats this
Forgot pic
/ So whats this #3
300 series stainless would be my guess. Lead doesn't work well for drifting, and stainless flows well when whacked hard.
/ So whats this
All my drifts are brass wouldnt this damage what your beating it on ?
/ So whats this #5
Depends on what the goal is. :)
Driving a big seized pin out of a gear - do you want the pin out, or do you worry about marring the end of it?
/ So whats this #6
I'm with Jim looks like stainless.
/ So whats this #7
Lead would mush out on top and bottom way more when hit over the years. We have many lead hammers, but no lead punches where I work.
/ So whats this #8
Also, if it was lead, you could take a sharp item and scratch it pretty easily. Give it a try.
/ So whats this #9
Probably a mix of stuff, stainless and maybe nickel.
/ So whats this #11
If lead you would be able to shave a small piece off one of the burls.
/ So whats this #14
Take a "slice" off one end and see what it looks like inside,
it looks like it could use a slice, before chunks of it go flying in your face.
/ So whats this
Take a "slice" off one end and see what it looks like inside, it looks like it could use a slice, before chunks of it go flying in your face.
Your right on that one it could I'll see if my bandsaw will cut it
/ So whats this
I cut one end heres a pic
/ So whats this
Was it easy to cut? Or was it hard like Ni-Hard steel. I tend to think it is a wedge for splitting logs and was later used as a punch.
Well its definitely hard but my bandsaw cut it not fast
2021 Kubota SVL75-2 Track Loader (A63689)
2021 Kubota...
Brandt 820XR Side Extensions (A63117)
Brandt 820XR Side...
Volvo EC220EL (A60462)
2025 Future X39 Hydraulic Trencher Skid Steer Attachment (A61572)
2025 Future X39...
Deutz D 2011 L03 Engine, 3-Cylinder Diesel (A63689)
Deutz D 2011 L03...
2017 Chevrolet Sonic Hatchback (A61574)
2017 Chevrolet...
