So I did a thing... Agria 8900D
   / So I did a thing... Agria 8900D
I've thought about it but it would only work for non PTO powered implements. Anything that uses a PTO, will just get in the way.
The PTO gearbox on this tractor bolts on like an add on, so it sticks way out the back. Adding to that, the PTO shaft that actually gets used, sits too low. It's very easy to get the PTO shaft on a bind due to excessive angles and that also puts the PTO shafts almost inline with the arms.
Shims to adjust the spacing between the arms and the vertical sliding plate are my only option right now.
   / So I did a thing... Agria 8900D #162
(y)
So the other day, I noticed the alternator getting way too hot and them letting out the magic smoke. I went and grabbed my ammeter and it was drawing nearly 3 amps with nothing On.
Turns out the rectifier just decided to quit. After a long time researching, since there is virtually no numbers on the alternator, I found a replacement rectifier.
This also brings me to the topic of the starter. Ever since I got it, the coil will do this weird thing where it pushes the bendix out but as the motor starts spinning, it will go back in, which causes a lot of grinding noises. I've opened it, cleaning everything inside, checked everything, including taking the coil apart and checking and measured the coil resistance. All good but still does this weird thing like every 2 times out of 3 attempts.
Anyway, I've started working on the tiller. Lots of fabrication work on the cover. The mechanical part is surprisingly in good condition. Just needs new seals and a good clean up. Oh and the bottom of the gearbox has worn out quite a bit. I'll add some plates to give it a fighting chance.
   / So I did a thing... Agria 8900D #164
I probably missed it early on in the thread, but that top PTO shaft I'm assuming runs at double or half speed?
That top PTO shaft runs double the speed of the bottom shaft and it's a smaller 1 1/4" 6 spline shaft. The bottom is the standard 1 3/8". The top is always engaged. All the time. Unless you press the clutch.
Since the High/Low range + Reverse gearbox is before the PTO and 1st to 4th gears, both PTO shafts have essentially High and Low range + Reverse on top of the 540 + 540Eco on the bottom shaft.
Kinda of a different setup and one does need to be aware that the PTO shaft will spin in reverse, when the tractor is going backwards. Some implements can get damaged doing so.
Some more pictures on the tiller. Mainly the gearbox.
All the shafts on this tiller use a labyrinth style seal, for the lack better word. Not an actual seal, but create the same effect since the flanges have this lips sticking out. The seals are behind that labyrinth and are just standard rubber seals.
Input shaft. As you can see, not leaky at all. It dumped all the oil on my trailer during the entire time I was working on the tractor.🤦‍♂️
The other end of the gearbox. Note the wear on the bolt heads and actual gearbox from dragging on the ground for who knows how many hours. The bottom bolt wore half way through the head and even exposed the hose on the big flange. I will add some material using flat bar.
The internals of the gearbox. Really in fantastic shape. Gears and bearings are perfect. It actually uses bigger bearings than my big tiller.
Today I got all the seals, a new U joint for the super short PTO shaft this uses and some more kerosene to use on the parts washer so I can wash all these parts.
Not an huge fan of these tillers with the gearbox in the center but with this tractor, that actually works well. Since the tines are "open" in the sides, it lets it steer with the tiller still on the ground very easily.
Remember my ordeal with the charge light and the need for a diode? Well, turns out that light was doing it's job perfectly all along. It was telling me that was something wrong with the alternator. I should've figured that out since just about everything in this tractor was broken in one way or another.
Yesterday I got my replacement rectifier. Put it on the alternator, tested it and worked perfectly. Then I bypassed the diode and sure enough, the light goes out as intended.
I removed the diode since that would actually preventing me from knowing if it was actually charging or not.
I realize I kinda neglected this thread, however, I did finished the tiller and got going again, which makes the project pretty much completed.
So far I've put about 6 hours on it. A couple of adjustments needed here and there, perfectly normal. Mainly brakes, without split brakes, it's a bit tricky getting both wheels braking equally, so I need to go up to speed and brake gently to see which wheel locks up first, then proceed to adjust.
I can say, this thing without power steering, it's an handful for sure, specially dragging an implement on the ground like the tiller. It probably doesn't help that I replaced the old cracked and bent steering wheel with one that fairly smaller in diameter.
It does have a different gear pattern but once you get used to it, it's actually nice and kinda makes sense being that way. All the controls work very nice and smooth, I'm super happy with how it feels.
The low profile is great. I can fit this tractor in places I thought I would never put a tractor in there.
The tiller was disappointing, even though the tines are wore out, I would've expected better performance from it. It barely scratches the surface and I have to do multiple passes to even get an half decent job out of it.
I think I figured out why it's not working very well. I believe someone put shorter tines for some weird reason. I still have to go and measure the tines to confirm this theory though. That's another €120 for 24 new tines.
Eventually, I'll make a video with all the pictures, including some machining videos.
A couple days I ago, I test fitted the brush cutter on the little Agria. It's too big for and a little bit on the heavy side but still managed to lift it. Ideal cutter for this tractor would be at 1 meter width. This is one is 1.3 meters and being that it uses chains, it makes for a lot more load on the tractor.
I didn't get to run it because it would require me to cut the PTO shaft about 150 mm. While it would still leave plenty of overlap for the Branson, I still rather cut if I really need to use this cutter on the Agria, so I'm holding off on that.
   / So I did a thing... Agria 8900D #170
View attachment 870268 View attachment 870271
It looks angry with it on the back though. Like it is ready to get serious. :ROFLMAO:
2008 CATERPILLAR 12M MOTOR GRADER (A51406)
2008 CATERPILLAR...
Giyi Mini Side Shift Forks (A53316)
Giyi Mini Side...
Kubota RTV500 (A47384)
2021 Kubota RTV X900 4x4 Utility Cart (A55787)
2021 Kubota RTV...
2013 Ford F-150 Ext. Cab Pickup Truck (A53422)
2013 Ford F-150...
(5) Flow-Guard Stainless Steel Filters (A53314)
(5) Flow-Guard...
