snowman22
/ snowman22
thanks for the heads up' i have worked on cars since i was 12 and am a master gm tech as well as ase master tech that being said i havn't worked on many loaders. nothing ventured nothing gained i will keep you posted
/ snowman22 #12
Glad you took that in the spirit it was intended - forgot to mention, the CD I have (like the link, but for the 580B) shows a few "special tools" for working on that valve - one is a socket for removing the "float can" - the long add-on opposite the linkage end of the spool - basically, it looks like a version of one I have for those notched, round wheel bearing nuts found on some 4x4's front wheel bearings.
By now, that tool may be obsolete but if I needed one, I'd sacrifice a rarely used size of a cheap HF socket, and just grind out the space in between the "pins" that engage those slots in the end.
Dunno how desperate you are to get this going, but IIRC my CD manuals didn't take long from that vendor, and there are a few pages with decent drawings showing exactly what's gonna jump out atcha if you're not prepared :=)... Steve
/ snowman22 #13
One more thing to look for, and that is the load check for that spool.
Remove the load check valve and see if the spring and poppet is intact. Might be an o-ring also.
/ snowman22
i went and did a little troubleshooting and it looks like their is a solenoid on the control valve that turns on with the key. this valve has a dead short in it . it has to do with the float and the down. i am going to replace it and see what happens
2012 BRUMLEY MANUFACTURING DATA VAN TRAILER (A55745)
2012 BRUMLEY...
2014 Wanco NTCIP Towable Solar Message Board (A59228)
2014 Wanco NTCIP...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55853)
2006 iDrive...
2016 PETERBILT PB337 FLATBED TRUCK (A52706)
2016 PETERBILT...
John Deere 7410 (A53317)
John Deere 7410...
2022 FORD F-250 STX CREW CAB TRUCK (A59823)
2022 FORD F-250...
