Snowblowing rules of thumb
   / Snowblowing rules of thumb #31
Egon said:
Hockey pucks would make good projectiles. :D :D
Ropes, hockey sticks, and other odds and ends like dog bones hidden under a layer of snow are also interesting items to find.
As stated point the chute in a harmless direction?? if possible or have it angled down and try and keep the blown areas clear of debris.
And another little item but quite important. Have the snow blower placed so that it is not blocked in by vehicles that cannot move due to snow being piled up on them!:D :D
I caught one of those fiberglass driveway markers with my blower last winter. Its unbelievable how those things get wrapped around the auger and have to be cut off. There 30 minutes of my life I'll never get back.
   / Snowblowing rules of thumb #32
With 1 km of camp road to along and another 2 more to help other people to main road rocks is a problem. This is my first winter with tractor as I bought it new in the spring
   / Snowblowing rules of thumb #33
Well, you're going to love that. Keep the shoes high. Private road? Get a box blade to level it over summer. You look like your up off Hwy 11. Nice ride!:D
   / Snowblowing rules of thumb #34
Off 17 up 101 past Wawa. yup it a private road with camps and some live year round. I will in 3 or so years when I retire. Tractor is my retirerment prensent to myself.
   / Snowblowing rules of thumb #35
Note to self... Look out for gravel as it breaks shear bolts. Look into some sort of cab for next year. I now see what ya'll are talking about with the snow blowin back at ya! LOL!!
   / Snowblowing rules of thumb #36
Well spent a couple hours moving off the snow of the week. One small incident - caught my 250' cord that I had run out to the Kubota. Amazing a spool of wire had gone up 50% in just a couple months.
How do you keep the side ridges down. I had a longtime farm buddy say you will need cut them down or else the finger drifts will move in. My ridges are about 6" now and will likely grow as more snow shows up. I'm a little wimpy about tackling the side hills; I have wide turf tires that still seem to be pretty slippery.
Garth
   / Snowblowing rules of thumb #37
250' is a LOT of wire. :eek:
I wouldn't worry terribly about the sides of the drive - your blower should be able to shoot the snow out of drifting range. Of course it will drift some, just keep the piles strategically located so as not to be a problem.
   / Snowblowing rules of thumb #38
Snowblower got a workout today! :D A few spots were as deep as the body of the snowblower and the city plough left a mound four and a half feet tall at the road. Had to use the FEL to dig my way out at the end. Helped out a couple of neighbours with smaller green equipment too ;)
Anyway my tip adds to those who talked about cleaning the augers to avoid snapping pins if they freeze up afterwards. Much easier to clean blower if you leave it raised after you park it. Gives easier access to clean and clear out the snow that falls underneath. Then just let the hydrolic pressure off to let the blower float down to rest.
   / Snowblowing rules of thumb #39
I have developed some snow blowing "rules of thumb" over the years that some of you newbies to snow blowing may want to consider. I figure that I have moved about 5400 inches of snow with my three snow blowing rigs. Feel free to add to my list, I am always looking for new techniques:
RULE 1. This is an obvious one - don't put your hand in the moving augers.
RULE 2. Always clean all of the snow off of your equipment. I learned this the hard way the second time that I snow blowed. The snow blower was making a **** of a racket when I started, and then I noticed smoke coming from the drive belts in the back. So I shut it down and called the dealer. "Didn't you clean out the augers after you finished. When the snow melts it freezes on the bottom of the impeller assembly such that the impeller won't turn."
Now I clean off everything, but especially anything which if frozen could make it difficult to start the machine. With my new rig, I wipe all of the water off of the cab, clean off the wipers and pull them away from the wind shield. Of course, it helps if you have a garage.
RULE 3. Never put the blower on the ground on a gravel driveway the first time you use it, unless you enjoy changing sheer bolts. This way the ground will freeze better for future use. As a matter of fact I generally run my SUV up-and-down the driveway a few times in the snow to pack it into the gravel before I snow blow for the first time.
RULE 4. When the snow is deep, take smaller cuts of snow. My first run in the snow is very very slow, usually painfully slow. For a guy who used to race motorcycles professionally, this is very hard to do. My next cut might be a third of the width of the blower or less. I would rather make more runs and use a little more fuel, then be replacing belts as I did with my old snowblower. The guy who wrote the Kubota snowblower manual obviously has never snow blown before. It says in deep snow take the top layer off and work your way down. To me this is nonsensical. You're going to be driving a tractor in the deep snow and making a general mess. How about just taking a narrower cut of the snowblower potential? Anyway I have been doing this and it has saved many a belt on my old snowblower.
Thanks !! that's great info and Advise.
Russie
   / Snowblowing rules of thumb #40
I realise this thread is 8 years old but that being said, it is a useful thread.
I 'wash' down my blower with windshield wash fluid after I use the blower EVERY time. I use the cheap -35 stuff because the blower isn't going to see 60 mph and freeze on the windshield. By wash down I mean that I splash some in the fan and some more in where the chute turns just to make sure things stay loose. I also grease every time I use it. I have a can of chain lube I keep with the jacket I wear for snow blowing and it is always warm and sprays good.
1969 Lincoln Continental Mark III (A56857)
1969 Lincoln...
UNUSED FUTURE 32"...
Unused SDJ-4000 9,000lb Two-Post Electric Auto Lift (A55851)
Unused SDJ-4000...
2015 Ford F-350 4x4 Ext. Cab Liberator 3,200LB 1.5 Ton Crane Mechanics Truck (A55973)
2015 Ford F-350...
Blue Diamond 103709 (A53317)
Blue Diamond...
Unused 2025 CFG Industrial H15R Mini Excavator (A59228)
Unused 2025 CFG...
