Living and blowing snow in VT for 20 odd years has helped me create my little list:
- Before snow flies try to be sure your drive is clear from debris and marked w/ sticks or markers. Mark hazards too like low lying areas, culverts, stream beds etc.
- When starting out, always engage blower at low power in case something is frozen/jammed that you missed when putting it away after last use
- Keep the chute pointed down wind (if possible) and
always away from people, cars, buildings etc. You'd be amazed how far you can blow a hockey puck through a picture window. Don't ask
- Keep rpm's up, move at steady pace and listen for motor bogging/straining. Slow down or take smaller bites if you have too.
- If you have a long drive like me, keep a bag/box w/ you w/ shear bolts, tools, flash light. Then you don't have to hump your butt back up to the house to get them when you break a bolt
- Only use proper grade bolts for shear bolts/pins. Would you rather replace shear bolts often or your blower?
- Keep up w/ your maintenance - the key to longevity
- Clean your gear after blowing. Any snow/water/ice left on it can and will freeze mechanicals in place. This leads to broken and/or malfunctioning equipment.
- Place blower on pallet or such so you don't end up frozen to the ground or leaving rusty marks on your garage floor
- And goes w/out saying, but never, ever reach or stick anything into a running blower. I won't even touch the auger unless the tractor is shut down never mind the PTO.
- Have fun doing it!!
j
