Snow Snow Removal JD4100
/ Snow Removal JD4100 #11
markcg2000,
I believe I ask first for some snow so I could get a little seat time. /w3tcompact/icons/laugh.gif
Are you 100% sure your wife hasn't?? /w3tcompact/icons/wink.gif
Thomas..NH /w3tcompact/icons/wink.gif
/ Snow Removal JD4100 #13
Carl, let me get my 2-cents worth in here.... I have a similar tractor, ie. 4100Hydro, Turf Tires, Ballast in rear tires, and I got the quick-tatch hitch and 47" snowblower with Hydraulic chute control and remote spout cap control. I also got the rotary broom and blade for the quick-tatch hitch. We finally got a decent snow here in New Hampshire, so I got to try it out yesterday - and what a snow removal machine it is !!! I have a lot of paved drieway to clear, and I don't want to pile up snow around it. The blower throws it far and fast, and then the broom takes me right down to clean pavement, although honestly the blower removes snow well enough that the broom is not necessary. Of course, depending on your requirements, you might not want to go this way - but if you're considering a snowblower, then I'd highly recommend this setup. As I said I also got the blade, which I use for clearing some walking paths, etc. This one turned out to be everything I was looking and hoping for and then some... :)
/ Snow Removal JD4100 #14
Caretaker, that is a pretty picture! Now tell me about that "rotary broom." I don't have to worry about snow, but I've looked for a way to sweep or clean up the ground under the pecan trees before the pecans fall; a way other than that long handled rake, that is.
Bird
/ Snow Removal JD4100 #15
Bird, thanks for your kind words. The rotary broom is a 51" front-mount, made by JD. It mounts via a quick-tach hitch on the front of my 4100Hydro. I believe the broom was originally designed for the 400 series tractors. It's PTO driven, and the quick-tach hitch provides up/down & left-right movement, so you can pick the broom up, or angle it left or right. It has adjustable gage wheels on the back, and parking stands on the front. The parking stands are reversed during use so they're out of the way. Typically you run it with the hyd. up/down control in "float", and the gage wheels keep the bristle ends at the correct height. The bristles are pretty heavy duty - they appear to be some kind of nylon or hard plastic. The broom is essentially a large roller, made up of segments, which are replaceable - either a kit which contains all the segments, or the individual segments. I haven't replaced any yet, so I don't know how hard or expensive that is. I primarily use it on paved driveway - One of the main reasons I got my particular setup was to help me keep the driveway cleaned off. I've swept dirt, sand, snow, and 1/2" gravel with it. It works great, really gets the driveway clean, and it's a heck of a lot faster than using a hose! It also works very well as a dethatcher for the lawn - leaves the dead grass in nice windrows. I'd think that for sweeping leave litter, etc. between rows in an orchard it would work pretty well, depending on what kind of surface you have underneath. I'd think that would be the main concern - can you sweep the trash off without disturbing the surface underneath. Hope that helps - let me know if I can give you any other info. Dave Wells
/ Snow Removal JD4100 #16
Thanks, Dave. That sounds like a nice rig, and I sure believe it would do what I want. I had hunted on the internet before for those type brooms and never could find any; probably using the wrong search words. By using "rotary broom" I found a manufacturer earlier today and e-mailed a request for more information. I want a 3-point hitch type, PTO powered instead of hydraulic if I can afford it.
Bird
Carl,
I plow my 800 foot gravel driveway with a JD 54" front blade. This is the second winter, and it works pretty well. I usually plow in the dark before work, and going forward just seemed easier when I bought the blade. My driveway is usually hard enough that I can use the float position, and not move too much gravel. In spring I plow back along the edges and put the gravel back on. The cost is higher than a rear blade, but for me it was worth the extra money.
/ Snow Removal JD4100 #18
Carl, I have a 4100 hydro with R4's and the 60" loader. It works great as a snow removal machine. The loader can't be angled like a straight blade, but works just fine pushing the snow straight ahead. Lay the bucket flat on the ground and then rotate the cutting edge up slightly and then have fun! The snow builds up in front of the bucket until some of it spills off to the sides. Make several passes and you will get the job done. All while looking straight ahead, no sore neck. Unless snow removal is your main concern, I wouldn't buy a blade when the loader can do the job just fine. Just my 2 cents. HarryW
/ Snow Removal JD4100 #19
I've used the 3pt snowblower a couple of times now and it's worked great.
I picked up a backblade this summer for $125 from my dealer. It is extremely lightweight (<100#), but I'd intended it strictly for moving snow and gravel. maybe brush piles (NOT trees)... never for true grading. That may be an option for snow removal. I'll still be keeping the lightweight blade even after I finally get the box blade.
The main reason I got the tractor was for a 3pt rotary cutter (BushHog-like, but painted <font color=green>green</font color=green> /w3tcompact/icons/smile.gif). I found it hard enough to hook it up with it's wheel in the back /w3tcompact/icons/tongue.gif; I don't want to go through the hasssles of connecting a heavy back blade when I just want to move a pile of brush or whatever.
Then again, it may turn out that I'm able to maneuver the tracotr better by next year so lining up the 3pt won't be so bad /w3tcompact/icons/laugh.gif
mark
Mark: Can you comment on the 5' snowblower usage? I have a 770 and will some day purchase a blower, but we just haven't had much snow here in NE PA the past few years. I suspect 60" is the perfect width, is it? If our gear ratios are the same, is low range/reverse the speed to use? I have a 60" JD front blade and it is great! A local Woods dealer has a 53 or 54" blower available (probably cheap) but I think it would be a bit too narrow-my rear turfs are that width. How is the Meteor? I really like the Pronovost but don't want to spend that much on a blower. The 770, by the way, has been COMPLETELY flawless for 3+ years and I would want no other tractor for my application! Thanks for your input.
2011 HEIL TRAILER INTERNATIONAL CRUDE TRAILER (A60736)
2011 HEIL TRAILER...
2016 Land Rover Discovery Sport 4WD SUV (A61569)
2016 Land Rover...
2017 FORD F-550 SERVICE TRUCK (A58214)
2017 FORD F-550...
2013 PRATT INDUSTRIES GARDNER DENVER TRIPLEX FRAC PUMP (A60736)
2013 PRATT...
Cat CB24B (A60462)
Cat CB24B (A60462)
2023 Unverferth 3PT 6 - FT Perfecta Field Cultivator (A61307)
2023 Unverferth...
