Snow Attachments SNOW REMOVAL HELP
/ SNOW REMOVAL HELP #1
chrispratt11
John Deere 4310
Hello,
I have a JD 4310 and plan on plowing my own driveway for the first time this year. My driveway is a steep 300 - 400 yards, I live in New England so we get a fare amount of snow. I'm not sure if I should be thinking snowblower or front blade and or if I need chains. I was offered a used AF12 for $1,500. Any help would be appreciated.
/ SNOW REMOVAL HELP #2
What state you in? Are you in open country or heavily forested? How was the driveway cleared in previous yrs?
Your 4310 a 32hp? Do you have a cab?
chains? probably on rears would be more than enough. my 1st preference is a snowblower.
BTW, already cleared the driveway once this year.
/ SNOW REMOVAL HELP
I live in New Hampshire. Pretty open but not open country. Driveway was plowed years past but prices are up to $80.00 each plow
/ SNOW REMOVAL HELP
Also have a gravel driveway. Worried about throwing pins with the snowblower. Does that happen a lot. I can't seem to find prices for a snowblower vs bade
/ SNOW REMOVAL HELP #5
i like the idea of a blade and a blower. i've got a rear mount blower and plan on putting a blade on frt for small storms(4 to 6 inches). Windrow snow into middle of driveway and snow blow in one pass. Or maybe a frt mount blower w/ a rear blade? Use the rear blade for cleaning up close to buildings and garage doors?
Many ways to go, but i think a set of rear chains is a must.
Are your rear tires loaded? All this stuff can add up to some serious $$$'s. But, it could be worth it.
/ SNOW REMOVAL HELP #6
My gravel drive is 650ft. go light the 1st pass or two and freeze down. Been blowing for yrs, have only sheared a few pins and those were from ice hard banks and getting too aggresive.
more will chime in. i have to get up at 2am. Wiil check thread tomorrow.
Good Luck.
/ SNOW REMOVAL HELP
Yeah, tell me about it. Def. getting chains. Tires are not loaded. Some guy is selling his AF12 blade for $1500 but I can't tell if thats a good deal. I was trying to get set up for 2K possible?
/ SNOW REMOVAL HELP #8
That's a pretty long driveway - I would consider a blower. You can do it with a blade but a blower will be much faster/easier and will eliminate some of the traction issues.
/ SNOW REMOVAL HELP
Really, I thought a front plow would be the fastest and most popular but that does not seem the case?
/ SNOW REMOVAL HELP #10
How much snow do you generally get at a time? I have a 1010 JD with a blade, tire chains and a Kubota L2250 with a bucket, filled tires and chains, I do most of my plowing with a Suzuki 500 4 wheeler, no chains. My drive is .2 mile long, gravel and if I don't let the snow get over 12 inches before plowing, I can plow as fast as I wish with the 4 wheeler. I'm in Western Maryland, last year one snow was over 30 inches.
/ SNOW REMOVAL HELP
What could I expect to pay for a front blower? What size?
/ SNOW REMOVAL HELP #12
I suggest you also consider what happens after you plow your driveway. Is it out to a county road? Or, will you also need to occasionally do a mile or so of county roadway to get where you need to go? That's the deal in my case. Getting to the road is 800 ft. I can do it with my plow in 2 minutes or less. So what. If the snow storm is that bad, I also need to do a mile of township road (and back) in order to get out. Then there are the neighbors who appreciate a plow's quick response.
A snowblower at crawl speed isn't going to cut it for us. Chances are that when you are done, you'll have to start all over because of the hour it took you to clear the drive and the roads.
/ SNOW REMOVAL HELP #13
This works for me, haven't met a storm yet it couldn't handle, and I believe your 4310 has more HP than my 2310 (23HP).
I have a gravel drive, about 250 feet; yes, it will throw stones, but as was mentioned, lower skids to raise the blower for the first few times and/or pack first few storms down to create a base. I lose a shearpin once in a while, but simply carry spares with me. No biggie.
Advantage is no high snowbanks, and it really is pretty fast- perhaps not as fast as a plow, but I like the "no snowpiles & banks" aspect of a blower.
However, a front-mount blower, including its front-mount assembly and mid-PTO driveshaft, is not cheap! Expect it to come to around $3500, perhaps more. I still consider it worth every penny. (Does your 4310 have the Mid-PTO option?)
Chris- if you're anywhere close to Leb/Enfield, come on over and see it!
  • blower 12:1:08.jpg
    blower 12:1:08.jpg
/ SNOW REMOVAL HELP #14
Hello Chris,
I agree with the snowblower and if you can swing it go with the front mounted blower. I have a rear mount blower and it is much slower and a bit tough looking backwards all the time.
Main reason I purchased the rear blower was the price. I picked up a used one for under $900 in good shape. I also felt I wanted the FEL for use, but I don't think I've used it more than a dozen times in four years. Prior to that I used a rear blade and the bucket to move snow around with and it was certainly a major task!
By the time you purchase a front blower, sub-frame and PTO kit you could be talking anywhere from $3.500 to $4,500.
I have a Kubota and the sub-frame so I will be adding a front plow this rear for handling the small snowfall situations and then just blow the edges, at least that is the plan.
The blower works great with 6 or more inches of snow, but small amounts or extremely wet snow can be a bit of a pain to handle.
/ SNOW REMOVAL HELP #15
A front plow blade is definitely the fastest, but you'll need space to accumulate the snow banks through winter. It also depends on the size of your tractor. A larger tractor has the weight advantage for a plow, and can drive through 2' or snow with the plow raised if needed. A plow works for me without chains but some storms I can't move much snow on the return trip back up the hill/drive. Plowing the drive in 3rd gear/medium range is about the same speed I drive out with my car or truck. Down and back, and the drive is passable but I continue to dress it up and move the main bank off the drive so it's ready for the next storm. I push all the snow to one side to reduce drifting.
There are heavy storms that a blower would be better, but I keep the blade up 6" or so and plow the whole drive that way. Then drop it down and plow it again. I don't have a cab so the plow keeps me drier.
/ SNOW REMOVAL HELP
Thanks everyone. I'm really thinking I want to spend around $2500 for the whole set up. It would seem like the front plow might be the only choice with this budget eh?
/ SNOW REMOVAL HELP #17
Chris, where are you in 'Hampster? I am mid-state near Plymouth.
My drive is half a mile long and changes elevation significantly (200+ feet).
In the last 12 years I have been through the gamit of snow removal equipment. Plow blade + rear blade + Loader work fine, but you will put a lot of hours in, especially as a heavy snow winter lingers on. The biggest issue is moving the built up snow banks that occur using a plow, time and time again.
FWIW I recommend you get chains as one of the first acquisitions you make. Nothing brings on "pucker factor" faster than a tractor sliding on ice down a hill...........NOTHING!
The blower idea is a great one and once acquired, will save you countless hours of dicking around with "old snow" because you put it well beyond the edge of the drive, pad, whatever.
The best solution is having options to make the best of each situation.
However, Starting out and in respect of your budget, I would recommend you acquire a used, power angle Fisher plow and mount it to the FEL. That and a rear scraper blade will do a fine job 90% of the time. Any additional work you need to do can be managed with your FEL. Takes a couple minutes to remove the Fisher and you are good to go.
My stuff includes two tractors, a big 100hp Hesston and a 3710 Kubota, a small fixed angle plow, a rear scraper blade, a Meteor blower and a 7' Fisher w/power angle. I have chain sets for both tractors, and conveniently the rear tires on the 3710 are the same size as the front tires on the Hesston. I also have a Herd sander for the 3710. see pickies below.
Get the chains!!!!!!!!!
/ SNOW REMOVAL HELP
Wow, Dead Horse, that is a great set up you have. Will look into the plow. Just got a estimate for a front blower 59 H $5,500! I think my wife would move out if I tried to slide that by. Def. getting chains, but they seem to run the gamet as far as price. Any suggestions? JD also gave me a estimate for a 7 foot hydrolic front blade for $2000.00 any thoughts on that?
/ SNOW REMOVAL HELP #19
I have a similar drive, with a section at 12% grade. Also, same size tractor with my JD4300.
I use a Western 7' front mount blade and have a wing for winging the snow "over the edge" or further back to tier the windrow back. Worked great for gravel drive, but now have asphalt and use chains a bit more often now. Sometimes, need to push the snow going downhill and buzzing back up empty if snow conditions are just right and don't have chains mounted.
Made a short video of the wing plow in action (going very slow as it was the maiden voyage) but if we get enough snow will make a better one this year.
YouTube - Wing_plow.MOV
/ SNOW REMOVAL HELP #20
For chains, I fabbed my own as I didn't want them draped down along the sides of the tire and so close to the fender on the inside. Bought cross links, and side chain, assembled from there with the additional connecting parts. At the time, about $200.
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
JOHN DEERE 750 GRAIN DRILL (A58216)
JOHN DEERE 750...
2017 Cadillac Federal 70IN Limo w 27466 Miles, Premium Federal Coachwork, Luxury Transport (A63688)
2017 Cadillac...
2007 CATERPILLAR 725 OFF ROAD DUMP TRUCK (A60429)
2007 CATERPILLAR...
2011 Ford F-250 RKI Service Truck (A61573)
2011 Ford F-250...
GMC 6500 (A63291)
GMC 6500 (A63291)
