Snow Plowing a Gravel Drive - Problem Solved!!!
   / Snow Plowing a Gravel Drive - Problem Solved!!! #31
With winter coming up, IM bumping this for those who may want to see it..
I was given a Land Pride RB1572 rear blade and got the horse mat installed on it this week.. Overall its pretty simple, the biggest issue was trying to get the edge+rubber lifted up and bolted to the blade the first time.. Once I got the first bolt in everything else was easier..
FYI - the bolts that came off the rear blade were 2" long 5/8" carriage bolt "type" (they set flush into the scraper edge).. Lowes didnt have 5/8" bolts so I went with 3" long, 1/2" bolts - DO NOT get carriage bolts (unless you want to make another trip back to Lowes - you need to be able to keep the bolt from turning) get regular headed bolts.. I used flat washers on both ends of the bolts. I also went with a lock washer and nuts with the nylon/locking inserts.
Im excited to see how this works this year.. First year with this blade and chains for the rear tires
Brian
   / Snow Plowing a Gravel Drive - Problem Solved!!! #32
I saw this before and I wonder how it will work on a crusted snow
   / Snow Plowing a Gravel Drive - Problem Solved!!! #33
I also bought some skid shoes for a Polaris ATV Ranger to put on the bottom of my bucket to keep it from digging into the gravels driveways I clear..
   / Snow Plowing a Gravel Drive - Problem Solved!!! #34
Have you ever tried pulling the blade backwards. Works well for me
   / Snow Plowing a Gravel Drive - Problem Solved!!! #35
This does sound interesting, I may consider this also on my front blade,
I just don't understand how this rubber mat added, " would not still pick-up stone',
can someone explain this to me.
   / Snow Plowing a Gravel Drive - Problem Solved!!! #37
I think its because the rubber mat folds/bends, so its not a solid point on the ground.. I think of of the pics in Post #1 shows how it bends
b
   / Snow Plowing a Gravel Drive - Problem Solved!!! #38
You are the one ai was referring to and just a suggestion that has worked well on our tar and gravel driveway
   / Snow Plowing a Gravel Drive - Problem Solved!!! #39
The main reason I wanted to try the rubber mat was that it is wearing the sealer off my asphalt driveway. After a really snowy year I have to reseal my driveway due to all the wear. Same reason for trying the skid shoes I bought for the bucket.
Brian
   / Snow Plowing a Gravel Drive - Problem Solved!!! #40
I did not read close enough and yes my blade does remove sealer from the paved part of our driveway. Sounds like your solution will work really well
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55852)
2006 iDrive...
2017 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2017 Ford F-150...
ELECTRIC GOLF CART (A58214)
ELECTRIC GOLF CART...
2015 FONTAINE 53 DROP DECK (A55745)
2015 FONTAINE 53...
(2) GOLF BAGS W/ CLUBS (A54757)
(2) GOLF BAGS W/...
NEW Skid Steer Attachment Plate (A59000)
NEW Skid Steer...
