Snow Plowing a Gravel Drive - Problem Solved!!!
   / Snow Plowing a Gravel Drive - Problem Solved!!! #81
Yes I assume casters would work but I am not a fan especially in the winter - I would think the casters would be digging in and leaving a trail of marks etc. I prefer a nice clean look.
I’m sure they would freeze up and then the wheels wouldn’t turn. Then they would drop down and dig into the gravel like skid shoes.
   / Snow Plowing a Gravel Drive - Problem Solved!!! #82
I know this is an old thread but I had a Fisher V plow that used a rubber flap in the middle for proper clearing. Well I cut out two pieces of a stall mat so it could be 2x as thick. Even used fender washer for backing. It didnt even last 2 storms. They do bend alot though. Cutting the piece out of a bias ply tire worked for years after that and sold it working.
On a side note..all the big parking lot snow pushers you see usualy have a rubber edge thata very very thick. That's how they clean so well.
   / Snow Plowing a Gravel Drive - Problem Solved!!! #83
When you analyze how windshield wipers work you'll soon accept why stall matt strips do so well on a plow blade.----- I.E.- you are wiping, not scraping.
I'll repeat my solution of cutting matts:
Simply drape the matt over a 2 x 4 and use a fresh blade and some sort of guide.
Draping will open up the cut as U move along and greatly reduce friction.
   / Snow Plowing a Gravel Drive - Problem Solved!!! #84
When my mile long gravel driveway has not yet frozen hard - I reverse the rear blade 180 degrees and go like smoke and oakum.
This works fine for me. Gravel stay where its been placed - snow bladed to the ditches.
UNUSED WOLVERINE TQH-26-01C 3 PT QUICK HITCH (A57193)
UNUSED WOLVERINE...
2016 International WorkStar 7400 21ft Cylinder Pallet Flatbed Truck (A55852)
2016 International...
2018 Isuzu FTR Landscape Dump Truck (A55852)
2018 Isuzu FTR...
UNUSED WOLVERINE MSG-11-44W 44" HYD STUMP GRAPPLE (A57193)
UNUSED WOLVERINE...
2019 TAKEUCHI TL12V2 SKID STEER (A52707)
2019 TAKEUCHI...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
