Snow Plowing a Gravel Drive - Problem Solved!!!
   / Snow Plowing a Gravel Drive - Problem Solved!!! #31
With winter coming up, IM bumping this for those who may want to see it..
I was given a Land Pride RB1572 rear blade and got the horse mat installed on it this week.. Overall its pretty simple, the biggest issue was trying to get the edge+rubber lifted up and bolted to the blade the first time.. Once I got the first bolt in everything else was easier..
FYI - the bolts that came off the rear blade were 2" long 5/8" carriage bolt "type" (they set flush into the scraper edge).. Lowes didnt have 5/8" bolts so I went with 3" long, 1/2" bolts - DO NOT get carriage bolts (unless you want to make another trip back to Lowes - you need to be able to keep the bolt from turning) get regular headed bolts.. I used flat washers on both ends of the bolts. I also went with a lock washer and nuts with the nylon/locking inserts.
Im excited to see how this works this year.. First year with this blade and chains for the rear tires
Brian
   / Snow Plowing a Gravel Drive - Problem Solved!!! #32
I saw this before and I wonder how it will work on a crusted snow
   / Snow Plowing a Gravel Drive - Problem Solved!!! #33
I also bought some skid shoes for a Polaris ATV Ranger to put on the bottom of my bucket to keep it from digging into the gravels driveways I clear..
   / Snow Plowing a Gravel Drive - Problem Solved!!! #34
Have you ever tried pulling the blade backwards. Works well for me
   / Snow Plowing a Gravel Drive - Problem Solved!!! #35
This does sound interesting, I may consider this also on my front blade,
I just don't understand how this rubber mat added, " would not still pick-up stone',
can someone explain this to me.
   / Snow Plowing a Gravel Drive - Problem Solved!!! #37
I think its because the rubber mat folds/bends, so its not a solid point on the ground.. I think of of the pics in Post #1 shows how it bends
b
   / Snow Plowing a Gravel Drive - Problem Solved!!! #38
You are the one ai was referring to and just a suggestion that has worked well on our tar and gravel driveway
   / Snow Plowing a Gravel Drive - Problem Solved!!! #39
The main reason I wanted to try the rubber mat was that it is wearing the sealer off my asphalt driveway. After a really snowy year I have to reseal my driveway due to all the wear. Same reason for trying the skid shoes I bought for the bucket.
Brian
   / Snow Plowing a Gravel Drive - Problem Solved!!! #40
I did not read close enough and yes my blade does remove sealer from the paved part of our driveway. Sounds like your solution will work really well
2025 HT360W Mini Stand-On Track Loader Skid Steer (A55851)
2025 HT360W Mini...
(APPROX. 25) 4' X 8' X 3/4" OSB SHEETS (A52706)
(APPROX. 25) 4' X...
2019 Caterpillar DP35N 7,000lb Diesel Forklift (A55851)
2019 Caterpillar...
404 (A52706)
404 (A52706)
UNUSED FUTURE HYD MINI AUGER (A57193)
UNUSED FUTURE HYD...
WOODS 9021 BATWING MOWER (A57192)
WOODS 9021 BATWING...
