snow moving help?
/ snow moving help? #1
Noodlearm
SE Michigan
Kioti CK30, Cub Cadet LT 1050 lawn Tractor, Huskee GT Garden Tractor
I just plowed some (over 20" drifts in certain area) snow from the recent storm. I need help on the best way to plow (rear blade) with a gravel drive. I end up pulling a lot of gravel with the snow. If I raise the blade slightly of the snow, I miss too much snow (for my liking) in the dips and then on the slight bumps, I still pull gravel. Any suggestions by people more experience than myself?
Thx in advance
MODS, Is there anyway I can move this to the General Forum instead of just being in the Kioti Forum. thanks again
/ snow moving help? #2
If you shorten your top link it will angle the cutting edge and won't scrape quite as much gravel. Depending on how thick the gravel/limestone is there is really no way, I know of, to prevent moving stone. Unless you want to put skids on the blade. Also the heavier the blade the more stone it will pull. I hope this helps, good luck!
/ snow moving help? #3
Brian
The best way to control a rear blade so that you do not pick up stones is to use skid shoes or gage wheels. Here is a thread on the subject. Click Here.
/ snow moving help? #4
I always turn my blade around. My Dad does the same with his 8N. Works great for us. /forums/images/graemlins/smile.gif
RedDog
/ snow moving help?
Thanks for the replies. I will turn the blade around and see how that works as that is an easy solution. If that doesnt work, I guess I will have to put a little more time and effort into it and try the gauge wheels. Thanks for help all.
/ snow moving help? #7
I turned my blade around as well and angle it when I didn't have the FEL. If it isn't scraping it low enough, I would lengthen the top link to make the blade edge stand up a little more. It worked well on my 200 ft. drive and never had a problem getting out even with a 2wd pickup with no weight in the rear.
2017 Cadillac Federal 70 IN Limo - 30,529 Miles w Premium Coachwork by Federal (A63689)
2017 Cadillac...
2024 Schulte 5026 Batwing Rotary Cutter (A63688)
2024 Schulte 5026...
2012 DRAGON  130BBL VACUUM TRAILER (A65643)
2012 DRAGON...
2018 F-150 4WD (A63688)
2018 F-150 4WD...
2021 Big Tex 14ET 18' Tandem Axle Trailer (A62679)
2021 Big Tex 14ET...
2003 Proclaim Tanker Trailer (A64194)
2003 Proclaim...
