Snow Equipment Owning/Operating Snow clearing with a SCUT.
/ Snow clearing with a SCUT. #21
JDeerekid:
R-1's, R-3's; I am not going there :eek:. Jay :)
/ Snow clearing with a SCUT. #22
I plow with my ATV which is a Polaris 500. It is a flat 550' gravel driveway. Plowing is based on speed and not weight. I go about 10 mph. If you hit something solid, it could hurt.
More than about 9 inches of snow will slow it down quite a bit, and I doubt I could plow the snow up hill, unless I put chains on.
In my sitution, it can't be beat. Takes all of 10 minutes to plow the driveway (other than the apron). And I like not having to look backwards.
/ Snow clearing with a SCUT. #23
True, unless you have weight. Then its possible to base it on weight.
/ Snow clearing with a SCUT. #24
Putting the last few posts together says that plowing is based on momentum - the combination of weight + speed. The less weight you have, the more speed you need. Hence, an ATV needs a fair amount of speed, where as a huge loader doesn't need that speed. And, a truck is somewhere in between.
All of which suggests that the size of your tractor has a lot to do with plowing technique.
You can overcome the issue with traction. Traction can come from aggressive tires/chains, or from weight, or both.
I plow my (level) driveway with a BX1500 - about a light as a tractor can get.
I have also driven it up a fairly steep, icy slope, which I can't explain, but it worked. Turf tires, too.
Actually, turf tires will be better on ice and hardpack snow (not better than chains, but better than more agressive tires) as there is more contact area. Big lugged tires get traction by biting into the material. You can't bite into ice - unless you have chains.
So, as others have suggested - get some chains, but first see if you can do it without.
7' Quick Attach Snow Push (A66408)
7' Quick Attach...
2004 Caterpillar 315CL Excavator (A64194)
2004 Caterpillar...
(1) 30 Yard Roll Off Dumpster (A65579)
(1) 30 Yard Roll...
New/Unused ATS 40 Gallon Two Stage Air Compressor (A65583)
New/Unused ATS 40...
84in. Light Duty Fork Extensions (A65640)
84in. Light Duty...
Rolling Cart Base (A65640)
Rolling Cart Base...
