Snap Ring Pliers.
/ Snap Ring Pliers. #21
Im replacing the clutch assembly on a van without pulling the compressor.
All I have left to remove is the coil and due to the hole depth and proximity to the radiator none of my pliers will work. Surely somebody makes one.
Any chance that there is a mechanic who works on those vans or AC nearby? It might be worth a trip and asking what he does.
/ Snap Ring Pliers. #22
Tekton has a variety.
5 Inch 90-Degree External Retaining Ring Pliers (0.047 in.) | TEKTON
/ Snap Ring Pliers.
I have all of these and probably a few duplicates. None will work in the confines I have.
There isnt much room between the shaft and the coil. I need a 90 degree pair with at least 1 5/16” tip reach.
It looks like I am going to unbolt the compressor. Not an easy task to reach the bolts. And hope there is enough play in the connections to allow me to use a straight pair.
I greatly appreciate all the suggestions and there are a few I will probably purchase for future endeavors.
/ Snap Ring Pliers. #26
The cheap KD pliers I've got have worked just fine on everything I own until I needed to replace the kingpin seals on my GC. I'm not totally satisfied with the only better ones I could find at the time but they got the job done, and on the second side too. If I ever come across some real good looking ones I will buy them so they can sit unused until my son or grandson inherit them.
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
2019 FREIGHTLINER M2 4X2 S/A NON 26FT NON CDL BOX TRUCK (A59914)
2019 FREIGHTLINER...
2022 EZ-GO ELITE...
CASE 580N BACKHOE (A65053)
CASE 580N BACKHOE...
JOHN DEERE 300P EXCAVATOR (A65053)
JOHN DEERE 300P...
New/Unused Wolverine 72in Quick Attach Brush Cutter (A65583)
New/Unused...
