Smoke from breather
/ Smoke from breather #1
LLK
I have a 1969 Cub Cadet 125 that has started to smoke from the breather, especially when hot and under a load.
What is the cause and the fix for this?
pkk220@charter.net
/ Smoke from breather #2
</font><font color="blue" class="small">( I have a 1969 Cub Cadet 125 that has started to smoke from the breather, especially when hot and under a load.
pkk220@charter.net )</font>
It might be due to crankcase pressure caused by compression blow-by past the piston rings.. It might need a cylinder hone/bore and new rings.
Bob B.
/ Smoke from breather #3
I agree with Bob! /forums/images/graemlins/smile.gif
/ Smoke from breather #4
Have you changed the oil lately?
/ Smoke from breather #5
What engine? Kohler "K" series? Like Bob says, given the age, you probably are ready for a rebuild. You could check compression to verify. The only other thing I could think of, is a stuck reed valve or blown out baffle pad in the breather box? I dont know what you have, but that could cause more oil vapor than normal to escape from the breather.
G/luck
Joel
(15) Kinze 48 Cell Bean Plates (A65640)
(15) Kinze 48 Cell...
2019 Chevrolet Tahoe SUV (A64557)
2019 Chevrolet...
20ft Jumper Cables (A65583)
20ft Jumper Cables...
Parker 500 Auger Grain Cart (A66285)
Parker 500 Auger...
2009 Infiniti G37 Coupe (A64557)
2009 Infiniti G37...
2012 VOLVO VNL 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2012 VOLVO VNL 6X4...
