Smoke from breather
/ Smoke from breather #1
LLK
I have a 1969 Cub Cadet 125 that has started to smoke from the breather, especially when hot and under a load.
What is the cause and the fix for this?
pkk220@charter.net
/ Smoke from breather #2
</font><font color="blue" class="small">( I have a 1969 Cub Cadet 125 that has started to smoke from the breather, especially when hot and under a load.
pkk220@charter.net )</font>
It might be due to crankcase pressure caused by compression blow-by past the piston rings.. It might need a cylinder hone/bore and new rings.
Bob B.
/ Smoke from breather #3
I agree with Bob! /forums/images/graemlins/smile.gif
/ Smoke from breather #4
Have you changed the oil lately?
/ Smoke from breather #5
What engine? Kohler "K" series? Like Bob says, given the age, you probably are ready for a rebuild. You could check compression to verify. The only other thing I could think of, is a stuck reed valve or blown out baffle pad in the breather box? I dont know what you have, but that could cause more oil vapor than normal to escape from the breather.
G/luck
Joel
2013 Chevrolet Silverado Service Truck (A62613)
2013 Chevrolet...
Aluminum Bell (A65583)
New/Unused 3 Point Hitch with Ball/Flat Hitch (A65583)
New/Unused 3 Point...
2007 INTERNATIONAL 4300 4X2 S/A UTILITY BODY TRUCK (A66091)
2007 INTERNATIONAL...
Glenco 20' Field Cultivator (A66408)
Glenco 20' Field...
FIFTH WHEEL ATTACHMENT PLATE (A65643)
FIFTH WHEEL...
