Cub Cadet Tractor 7265 Stuck in Gear
   / Cub Cadet Tractor 7265 Stuck in Gear #1
Andrewczw
Cub Cadet 7265
Hello, I have a Cub Cadet 7265 with hydrostatic transmission. The other day I drove it fine onto our trailer to transport it and turned it off while in gear. When I got it to the barn and went to unload the tractor, shifted it into Neutral and it wouldn’t start. It needs to be in neutral to start. So I jostled it a bit and made sure it shifted in neutral and still nothing. Battery is fully charged. The gear shifter seems to shift fine. While the shift lever is in neutral I tried pulling it off, and the tractor tires just drag, so I believe it’s not actually in neutral. So im guessing it won’t start due to being in gear? I’m guessing there’s a neutral switch keeping me from starting it. Is there a way to bypass the neutral switch or get the tractor truely in Neutral?
   / Cub Cadet Tractor 7265 Stuck in Gear #2
You may be able to turn it on with the key then jump it at the starter bypassing all safety switches to get it running. The concern there is having it jump when it starts. It may be best to have someone depressing the clutch if you attempt this method.
TAYLOR  WELL SERVICE WORK OVER RIG (A45333)
TAYLOR WELL...
2014 UTILITY 53X102 DRY VAN TRAILER (A43004)
2014 UTILITY...
2017 Yale GLC050VX 3,500 lb LPG Forklift  Powershift, Aux Hydraulics (A44789)
2017 Yale GLC050VX...
2012 TIGER MFG ACID TRAILER (A45046)
2012 TIGER MFG...
2008 TRAIL MASTER, INC. GOOSENECK TRAILER (A45046)
2008 TRAIL MASTER...
NUWAY PUP (A45333)
NUWAY PUP (A45333)
