Small tractors doing big work.
/ Small tractors doing big work.
/ Small tractors doing big work. #83
Small tractor doing big rock.
Bruce
/ Small tractors doing big work. #86
Not me. I've done similar in reverse, with a rock that fits in the loader bucket, but can't be lifted.
Bruce
/ Small tractors doing big work. #88
My 1981 Sears/loader/and Gannon rollover box blade.
You know, it seemed like the FEL buckets were larger on the tractors one time in comparison to today. That bucket is almost as large as mine, at 28 hp and 3 times the size.
/ Small tractors doing big work. #90
I used my BX25 to cut out the foot print for my 30x40 barn ( actual cut was roughly 40x50) and cut 12" down. It took a little time, kept it in low and 4 wheel drive but did a great job. Also I cut out a 40'x40' pad in front of the barn. After all said and done I laid more than 100 tons of #2 and 411's as well. The BX25 is a work horse, it just takes more time!
Now all we need are pictures of it. A friend or two at work here as bx25's.
/ Small tractors doing big work. #94
Not necessarily a big work but more like to show the versatility of these small tractors.
It is an hydraulic broom I've made of the B7000 I had a couple years ago. It worked really nicely and saved me lots of time by not having to broom all that space by hand. :)
Nice. Is that hydraulically driven or off the pto? When then first started to put the power take off on the back end of the tractor, I would have liked to have seen some of the homemade gadgets they come up with for whatever chore they were looking to do.
/ Small tractors doing big work. #96
It runs off a third function valve I've added to the tractor that power an hydraulic motor on the broom. I had to run another hydraulic pump out of the front of the engine for the loader. The original one is really slow, only meant for the 3 point hitch.
/ Small tractors doing big work. #98
I've put on about 1,100 hrs on my B7800 (bought it with 738 hrs). I have done things with it that some would call abuse; however, true "abuse" tends to produce breakages or premature failings; my B7800, though it looks like it's gone through a war, is still operating fully and capably. I could only claim one breakage in all those hours that I could claim was abuse, and that was bending a lower link arm: pushing with my indestructible box blade, at an angle (had done it plenty of times before but this one time that was it!). Parts costs on smaller tractors are small-ish.
Here's a G-rated operation from back when I was reconstructing a moved 10'x20' shed (even this would have put OSHA inspectors into cardiac arrest!):
The disassembly (holding sections of the roof up- not a truss roof- a real juggling act!):
I'd bought the B7800 before I'd even moved on to [this] property. It is a war-proven companion of which I never wish to part with. I could almost operate it with my eyes closed I'm so familiar with operating it in an insanely number of differing situations. Trailblazing duties have mostly subsided (most of property now discovered) and it's now mostly out "to pasture" doing grounds-keeping work around the home site (KIoti is now expanding and maintaining the larger reaches of my property).
I've done things with this B7800 that if I'd post about them I'm sure that someone would find a reason to lock me up!:eek:
I can raise up the B7800's bucket and climb up and into it, going from tractor seat and over along the loader stiffening bars (running parallel to the engine), like it's a jungle-jim. Great as a ladder!
/ Small tractors doing big work. #99
JD X495 with 24hp Diesel
54" hydraulic blade and 3pt hitch make this a real workhorse. Great for moving and leveling dirt and gravel. Perfect for the 2 - 3 times a year we get snow here.
I throw on the 62" mower deck to keep the yard in shape.
/ Small tractors doing big work. #100
I have dug out and "collected" a bunch of rocks my BX can't lift.
Recently used it to moved rented man lift in to tight space.
2019 INTERNATIONAL LT625 6X4 T/A SLEEPER TRACTOR TRUCK (A59912)
2019 INTERNATIONAL...
429872 (A61166)
429872 (A61166)
(2) Lights (A64119)
(2) Lights (A64119)
2014 Chevrolet Sonic Sedan (A61574)
2014 Chevrolet...
Ford F800 (A63689)
Ford F800 (A63689)
UNUSED WOLVERINE 6' FORK EXTENSIONS (A64281)
UNUSED WOLVERINE...
