Small Tractor reco - Primarily for snowblowing long drive
   / Small Tractor reco - Primarily for snowblowing long drive #1
Starrynights
ontario
Kioti ck2620
It looks like I will be moving to a farm in December (fingers crossed). The drive to the house is about 500m(canuck measure) or 0.3 miles(freedom units). I want to get a small tractor that will be multipurpose, but #1 job would be to clear the drive in the winter.
What are some good ones to look at?
Cheers!
   / Small Tractor reco - Primarily for snowblowing long drive #2
You need to determine how small is small and what the other purposes for the tractor will be. It sounds as though this will be your only tractor. How big is the farm? What other tractor jobs are planned? How much snow to you expect? What other implements will the tractor be handling?
The part I would be using the tractor on would only be a couple acres...
Move move soil/ firewood (ie tow a bin),
Mow lawn (if an attachment is possible).
Not sure of the annual snowfall, but expect it to have some significant falls during the winter (Possible for 50+cm at at a time.
Given the long drive, I don't want to go too small in the lawn/garden size (which is what I would need if I didn't have this as a task. Also... the drive is mostly flat, so no hills to deal with
   / Small Tractor reco - Primarily for snowblowing long drive #4
Sounds like a Sub-Compact tractor will work for what you're planning. Are you planning on purchasing new or pre-owned? What's your budget? What dealers are local to you?
I'd suggest looking at the Massey Ferguson GC1700, Kubota BX, Kioti CS, Yanmar SA, JD 1 Series and also TYM (and there are other great options). In reality, you really can't go wrong with any 'new' sub compact tractor offerings.
Mike
   / Small Tractor reco - Primarily for snowblowing long drive #5
Define mow lawn? Are we talking Bermuda Groomed or pasture grass you just need to knock down. The larger the machine the more difficult it will be to maneuver around a yard. Also weight of machine could leave tracks and swinging the rear mower could hit stuff by accident.
Good questions!
I want a groomed lawn.. likely will be a mixture including kentucky bluegrass (typical for the area). The lawn footprint is pretty much just a square box right now and open... but those are good points about the weight of the machine vs. the soil. Right now I don't have a good handle on that (will not be on site until December, and will not really see this until spring/summer.
   / Small Tractor reco - Primarily for snowblowing long drive #7
So by the sounds of it, you will not be farming? So for everything else you posted any brand that is the same size as my Kubota B2620 would do everything you need, or one with the factory cab. But stay 26 h.p. or under so you don't have to deal with constant emissions system problems.
Now if you needed an all around tractor that you could hobby farm with, then I would say go antique/vintage. Because then you could buy cheap, big power, heavy weight, run-forever-reliable.
Yes... thats correct. There are 60 acres, but will be renting that out for someone with real farming equipment.
Thanks for the suggestions! I will check out around th 26hp mark and that Kubota model
   / Small Tractor reco - Primarily for snowblowing long drive #9
Just to add to the mix, snowblowing on an open station tractor is not going to be very comfortable. I upgraded to a cab machine for winter use and don't regret it for a second.
   / Small Tractor reco - Primarily for snowblowing long drive #10
As an add on to the above post, I used to use an open station tractor with a 3 pt blower. Very cold, wet, and slow.
In 2009, I bought a skidsteer with an enclosed heated cab and a blower. It’s great. That would be my recommendation for snow removal.
I do my driveway and my neighbor’s - very large country driveways.
I'll check that sort of config as well.
It might make more sense to have that, and a separate mower.
   / Small Tractor reco - Primarily for snowblowing long drive #12
Tractor, cab and snow blower is also great…..and you can use it for many other things without paying $7000 per implement like you do on a skid steer.
I recommend a tractor cab and rear snow blower with a front buck or plow blade (if You have a ton of snow).
   / Small Tractor reco - Primarily for snowblowing long drive #13
Good questions!
So that finished lawn is the challenge. Normally I would recommend an entirely different machine (Zero turn or a garden tractor) For a groomed lawn. You could go tractor with a mid mount mower…but that would likely be a Kubota BX or JD 1 series. The larger the machine the more ridiculous a MMM is to take on and remove. Tractor with a rear rotary cutter is probably an issue if your lawn has any obstacles at all and you care about tracking it up.
   / Small Tractor reco - Primarily for snowblowing long drive #14
Mike
Normally, I think bigger is better, but I think a subcompact would work well for you. My neighbor has a Kubots GR2120 garden tractor with a front mount snowblower. I am impressed with how well it blows snow, and how it has enough traction with turf tires and no chains. We had 16"+ of heavy wet snow, and it it dispatched it well. The key was a front mount snowblower. He also mows his lawn with it.
AS BX or other subcompact would also perform both roles. A cab is nice, but not necessary - just dress warm.
   / Small Tractor reco - Primarily for snowblowing long drive #15
manicured lawn and skid steer??
I can just imagine what the lawn will look like after a few tight turns with a skid steer should he need it for other summer uses...
Do not miss my New Holland SS,
was thinking a bit larger for the Op like a cabbed JD 4 series and an inverted blower and keep the bucket / FEL
Then again he did say small. Tractors do tend to shrink after owning them for a while.
   / Small Tractor reco - Primarily for snowblowing long drive #16
Tracked skidsteer……doesn’t mess up the law at all. Actually used to snowblow paths through the lawn and fields with it for walking the dog.
   / Small Tractor reco - Primarily for snowblowing long drive #17
Buy the cheapest cub cadet you can at the big box store. Pay for delivery.
If you are lucky, next year you will be an educated consumer and have an idea of what is and isn't important to you.
Good luck on your new farm.
   / Small Tractor reco - Primarily for snowblowing long drive #18
A couple of things that haven't been discussed. If the budget allows, I would suggest looking at the JD 2 series and whatever corresponds to that in the other brands. They have larger rear tires, more ground clearance and are more capable. Don't shy away from mid mount mowers. With the current drive over decks and auto-connect systems, they are a breeze to attach and remove.
Adding a factory cab is way expensive and you will want one to do much snow blowing. However, fabric cabs (like my Original Tractor Cabs) are available for many popular models and are much cheaper. Depending on the amount of snow you expect and the terrain, consider a snow plow. It's cheaper and faster and works until the banks build up so much you can't push it back.
   / Small Tractor reco - Primarily for snowblowing long drive #19
Get a cab tractor, then buy a pto finish mower in the back. Easy to take on and off and cheaper then a mmm.
   / Small Tractor reco - Primarily for snowblowing long drive #20
Yep and to add to the benefits of going to a JD 2series or Kubota B/LX.....you don't have to remove the driveshaft to change a fan belt like the SCUTS.
And the drive over mm Mower deck on my Kubota couldn't be much easier. No wrestling at all. JD would be the same.
Me, I live in the snow belt. So I prefer the tractor with a blower. I had a Boss plow on the F550 Ford truck and I have one on the RTV.......but I like using the tractor and blower. Better visibility and no snow banks and nothing ever closes in on you. And no dug up gravel or lawn.
UNUSED FUTURE ELECTRIC WET POLISHER (A60430)
UNUSED FUTURE...
2016 Dodge Journey SUV (A59231)
2016 Dodge Journey...
2020 CATERPILLAR 306 CR EXCAVATOR (A60429)
2020 CATERPILLAR...
2013 BMW X5 AWD SUV (A59231)
2013 BMW X5 AWD...
2021 CROWN C5-1000-50 STRAIGHT MAST FORKLIFT (A60429)
2021 CROWN...
2007 MACK CTP713 TRI AXLE DUMP TRUCK (A59575)
2007 MACK CTP713...
