Small tractor or ATV and mower?
/ Small tractor or ATV and mower?
There are a number of large rock out croppings. Some of those are essentially not moveable. There are some smaller 2-3 foot boulder size outcroppings that will probably take a backhoe to get them out and moved. Longer term, the issue will be the 3-8 inchers that continue to emerge from the ground. I thought a rake might take care of that.
I am investigating the Power Trac now. It may be the vehicle for the rougher terrain that I can use for moving some of the smaller boulders once a back hoe digs them out. Maybe only limited mowing is the future, so something with good lifting and towing capability on rough terrain is what is now on the list.
I am not sure about the difference in functionality between something like a Power Trac and a small tracgtor such as a Kiot Ck20, Kubota BX, or similar small tactor.
/ Small tractor or ATV and mower? #43
I went through the same decision process your going through now about a year ago. I also didn't have much use for an ATV other than mowing and perhaps using it with other implements. After researching this forum and a number of searches, it seemed that the ATV/mower combination would be a comprimise and most comments suggested the combo just didn't work that well. The ATV combo did not seem all that inexpensive either. If your main goal is to actually do work with machine, then a tractor is probably a better bet.
I then, as you are now, looked at the PowerTracs. I have a lot of hills and these machines looked very interesting to me (and still do), in the end, I wasn't willing to purchase something that expensive without using/seeing it first (they are factory shipped, and don't have a dealer network). I was also concerned about repair/service- the factory is supposedly very helpful, but without a dealer network, you have to be handy if something goes wrong. There might be someone on the PowerTrac forum near you who can show you their machine.
I ended up with a JD 3320 from a local dealer, FEL, rotary mower, boxblade. I use it more than I thought I would, you will find a tractor is quite handy for a number of things that an ATV might not be- digging post holes, using a carry-all, FEL work, site prep (even dragging a shed to another part of my property). It was more $ than I initially wanted to spend, but in the end I use it more than the ATV.
The other vehicle I wished I looked at (which may be out of your price range) is the Toolcat. This vehicle looks like it would do everything my 3320 would do- and more. I think there may be forum on this vehicle now. Toolcat
/ Small tractor or ATV and mower? #44
/ Small tractor or ATV and mower? #45
Hotwheels,
If you have that many rocky obstacles, you will not be happy with the ATV/mower option. As I stated earlier, maneuvering and backing up with the mower attached is a MAJOR PITA. Turn radius is not small either. Also, there is no way to raise the mower deck height without dismounting from the ATV and manually doing so. You can stop the blade rotation from the ATV, as it has an engagement lever/key start (on the electric start version) which mounts on the rear rack of the machine, but it takes a moment for it to wind down. Another thing to keep in mind is when going downhill with the mower/ATV, there is a chance of the mower deck over running the ATV, as there is no brake on the mower, and the connection is a pin hitch, or a trailer ball, if you want to weld one on the mower tongue. The cost of the ATV/mower is not negligible either. $5000-8000 for the ATV with enough HP to pull the mower, and $1200-1600 for the mower. All in all, I would strongly suggest a good small tractor. I'd be looking for a good used Yanmar or Shibaura tractor with a 5' bush hog. Just my $.02.
/ Small tractor or ATV and mower? #46
Hotwheels,
I have ruled out the ATV option. I have the same reservations about the Power Trac: I don't have the time to fix it myself if it breaks and I am not interested in learning. Too many other things to do in life. So, the tractor is looking like the default option. The Tool Cat also looks interesting... we have a friend who sells Bobcats, so maybe they can offer us a deal!
If not, then I will find a small tractor that can haul and do the bucket and loading tasks that will make life easier long term.
/ Small tractor or ATV and mower? #49
On this rock issue, if you know someone in that business would it be possible to add dirt over the rocks? Some companies need a place to dump dirt.
/ Small tractor or ATV and mower? #50
/ Small tractor or ATV and mower? #51
</font><font color="blue" class="small">( I can take my ATV places you would never dream of taking your tractor )</font>
That's a 2 way street. I can take my tractor places you couldn't get your atv thru. /forums/images/graemlins/wink.gif
For instance.. ever have a big spider land on your face while brush cutting heavy growth, flip out, and then when you recover, you find that you have just mowed a 10' wide path thru a stand of 3" sweet gum trees that -used to be- 20' tall? /forums/images/graemlins/grin.gif Been there.. done that..
Soundguy
/ Small tractor or ATV and mower? #52
Soundguy
/ Small tractor or ATV and mower? #53
<font color="blue"> what I was thinking. Tractors are just too heavy to compete with an ATV as far as going off-road </font>
The difference being, when you are on an atv, you go around 3" diameter trees... On a big tractor.. you go over them... Anything that you can get the front axle to clear is usally more or less 'just like flat ground'..
That's why they do land clearing with big tractors, tracked equipment and such.. and not atv's.. /forums/images/graemlins/grin.gif
Soundguy
/ Small tractor or ATV and mower? #54
Soundguy
/ Small tractor or ATV and mower? #55
</font><font color="blue" class="small">( <font color="blue">
Soundguy )</font>
<font color="black">
That is certainly true - but pretty much any tool looks like a toy compared to something bigger. My ATV pulling a Swisher rough cut mower does a great job clearing trails. It does exactly what the big boys do - the mower mows down anything and everything the puller climb over. In my case the limit is somewhere around 2 inches.
To me, that is the definition of a good setup. It makes you think - WOW I barely drove over that thing and then my brush hog just destroyed it!
Plus I can fit between more of the 12 inch trees neither of us can go over. :) I imagine someone has a bigger rig which mows down even those :)
That said, unless you need something small to manuver between trees or if an ATV will get you places a tractor won't, the tractor certainly is a better brush hog.
Jim
/ Small tractor or ATV and mower? #56
Soundguy )</font>
Jim
/ Small tractor or ATV and mower? #57
Tractor for sure. My ATV is fun and good for getting somewhere quick on the property but can't do 3% of what the tractor can do.
Mike
/ Small tractor or ATV and mower? #58
Mike
/ Small tractor or ATV and mower? #59
Hotwheels,
The Toolcat would do what you are looking to do but unless your friend can get you one heck of a deal it would cost quite a bit more than the tractor price you listed. Also note, at least for me, it is not something you use in the lawn area. While it does not tear up the turf it weighs too much and will create depressions if you have soft spots.
Rent a Toolcat or skidsteer for a day from your friend with a grapple and a Brushcat to get your areas opened up so it is easy to maintain. I've rooted out several 2-3 ft boulders with my Toolcat, it's a little groundhog.
dsb
/ Small tractor or ATV and mower? #60
Hotwheels,
dsb
