Small engine oil?
/ Small engine oil? #1
dodge man
Super Star Member
West central Illinois
JD 2025R
Not another oil thread! I did a search and didn’t see it addressed. What do people do for small engine oil? It used to be straight 30 weight was called for but that seems outdated these days. I found some small engine 10w-30 Walmart branded oil and bought a couple of quarts. Is just regular synthetic 10w-30 ok, that seems like what I’ll probably start using.
Edit, the stuff I got at Walmart is straight 30 weight.
/ Small engine oil? #2
All my air cooled engines spec either 30w or 10w-30 conventional or 5w-30 synthetic with the exception of my Honda Rancher that says 10w-40. With that said I went to 1 oil for all the air cooled engines. Rotella T6 5w-40 years ago. Never a problem with this oil and easier starting in cold weather. In fact, just purchased a new inverter generator 3 weeks ago and after break- in of 5 hours I changed it to the Rotella T6. If I was using a gasoline rated oil I would probably go with 5w-30 or 10-30 synthetic, likely Mobil 1.
/ Small engine oil? #5
@dodge man Regular oil is fine and doesn't require synthetic. Lawnmower oil is formulated to operate at higher temps than regular auto oil, and also contains a higher zinc content due to the flat tappets.
/ Small engine oil? #6
I have a Toyota that specs 0w20 oil, so I put that in. Any diesel gets 15w40. My suburban would be expensive to replace so it gets the 5w30 it wants and so every other engine i own gets 5w30. Generally gas engines especially small ones will be totally fine with 5w30.
For me the $2 synthetic costs its not worth stocking conventional for a few small engines. I typically like to keep about 2+ yrs of oil changes on hand for every vehicle. I own 14 things that have a seat and you can drive.
/ Small engine oil?
I was running the Amsoil and got off that treadmill after I retired. Good oil but not worth the extra cost and the membership fees.
/ Small engine oil? #9
Where do you find "lawnmower" oil? Straight 30w "reduces oil consumption" per my JD zero turn manual. I usually add zink also.
1996 John Deere 8400 Tractor (A66285)
1996 John Deere...
2022 EZ-GO ELITE...
Club Car Emergency Cart (A64557)
Club Car Emergency...
Wagon Wheel Rocking Chair (A65583)
Wagon Wheel...
1967 Hyster C35T-3 Equipment Trailer (A66285)
1967 Hyster C35T-3...
2014 KOMATSU PC170LC-10 EXCAVATOR (A65053)
2014 KOMATSU...
