Slowing down hydraulic snowblower controls
/ Slowing down hydraulic snowblower controls #1
sailorman3
Newfoundland
Kioti CK3510
I have a 72 inch Pto snowblower on my ck3510 tractor. The chute moves much to fast up and down as well as sideways. I know I can install a needle valve to adjust the speed but I really don’t want to install four one way valves and bidirectional valves are not at my disposal. If I installed a piece of round stock with a hole drilled through the Centre in the lines where they attach to a threaded coupling, will this work? It shouldn’t be any different than the valve.
/ Slowing down hydraulic snowblower controls #2
Is the rotate a motor or a cylinder? If a cylinder you just an orifice in one line typically the cap end.
If a motor you may have to have an orifice in each line metering oil in and free reverse flow to prevent back pressure which could damage shaft seals.
/ Slowing down hydraulic snowblower controls #3
My broom swing cylinder lines have brass disc inserts that have about a 1/2 mm or less restrictor oriface disc hole in them. about a mm thick. JD part no. N204464. But, these lines have flat faced connections, not pipe or tapered.
/ Slowing down hydraulic snowblower controls #4
Are you running a hydrostatic and running the engine at PTO RPM continuously? One option is to just feather the levers,
i.e partially move them, rather than move them to full detent.
If I go full detent on my snow blower at PTO RPM I can slam the chute pretty hard, feather valve handle and it's smooth and fast enough.
Both have cylinders.
even trying to feather the levers they move to fast. I have to run it at full pto speed while moving and need to adjust the chute as I go.
/ Slowing down hydraulic snowblower controls #6
/ Slowing down hydraulic snowblower controls #7
TSC has restricted fittings available (male and female pipe threads) with an approx. 1/16 in hole for flow control. They can be drilled larger if too slow. One per cylinder should suffice. I have a number of them in use on: a front mounted snowblower lift cylinder, a dump cylinder on a 3 pt mixer, a swing cylinder on a 3 pt rake, and a top link for the 3 pt lift.
Unfortunately I have no access to a TSC, but I’ve seen those and I would purchase them if I had access. I can’t seem to find that particular valve in Canada.
/ Slowing down hydraulic snowblower controls #11
My needle valve works in both directions, so only needed 2 of them... there are ones that only work in one direction.
/ Slowing down hydraulic snowblower controls #12
There is usually an adapter between the hose and the actuator (motor or cylinder).
What I've done in the past, was to partially tap the hole in the adapter, then just use set screws of the same thread with a very small hole drilled (this can be drilled till you find the sweet spot or even do various set screws with difference hole sizes).
Finally install the set screw in the adapter, which will bottom out on the thread, hence why it's a partial thread and won't go all the way through, so it's locked in place. There is not real need for any thread locker or sealant.
I’m unable to find a bidirectional needle vale in any hydraulic shops in my area and can’t seem to find one on line either. The ones that show bidirectional have only one arrow on them. I already ordered one but I had to send it back because it wouldn’t work.
/ Slowing down hydraulic snowblower controls #14
A simple needle valve restricts in both directions and may or may not have any arrows. A flow control that restricts in one direction and free flows the other will typically have an arrow showing direction of controlled flow.
No that is incorrect. A needle valve is designed to restrict flow in only one direction unless it is a bidirectional needle valve. The arrows are meant so it is installed in the direction of flow.
/ Slowing down hydraulic snowblower controls #17
I have a cylinder on the deflector and a motorized chute rotator on my Woods SS74 PTO snow thrower. I use these inexpensive .045 restrictors on both hoses and they work fine:
That is exactly what I am looking for. Unfortunately the link is not working for me.
/ Slowing down hydraulic snowblower controls #20
I use the same type restrictor to slow the cylinder on my grapple. You only need one in one of the hoses.
Links:
Pardon Our Interruption
Informational Lot - Shipping (A61307)
Informational Lot...
TPL MECHANICS BODY LUBE SKID (A60429)
TPL MECHANICS BODY...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2003 LEEBOY L150 ASPHALT DISTRIBUTOR TRAILER (A52707)
2003 LEEBOY L150...
2018 BOBCAT T550 SKID STEER (A60429)
2018 BOBCAT T550...
Case-IH 165 Puma (A57148)
Case-IH 165 Puma...
