Slowing down hydraulic snowblower controls
/ Slowing down hydraulic snowblower controls #1
sailorman3
Newfoundland
Kioti CK3510
I have a 72 inch Pto snowblower on my ck3510 tractor. The chute moves much to fast up and down as well as sideways. I know I can install a needle valve to adjust the speed but I really don’t want to install four one way valves and bidirectional valves are not at my disposal. If I installed a piece of round stock with a hole drilled through the Centre in the lines where they attach to a threaded coupling, will this work? It shouldn’t be any different than the valve.
/ Slowing down hydraulic snowblower controls #2
Is the rotate a motor or a cylinder? If a cylinder you just an orifice in one line typically the cap end.
If a motor you may have to have an orifice in each line metering oil in and free reverse flow to prevent back pressure which could damage shaft seals.
/ Slowing down hydraulic snowblower controls #3
My broom swing cylinder lines have brass disc inserts that have about a 1/2 mm or less restrictor oriface disc hole in them. about a mm thick. JD part no. N204464. But, these lines have flat faced connections, not pipe or tapered.
/ Slowing down hydraulic snowblower controls #4
Are you running a hydrostatic and running the engine at PTO RPM continuously? One option is to just feather the levers,
i.e partially move them, rather than move them to full detent.
If I go full detent on my snow blower at PTO RPM I can slam the chute pretty hard, feather valve handle and it's smooth and fast enough.
Both have cylinders.
even trying to feather the levers they move to fast. I have to run it at full pto speed while moving and need to adjust the chute as I go.
/ Slowing down hydraulic snowblower controls #6
/ Slowing down hydraulic snowblower controls #7
TSC has restricted fittings available (male and female pipe threads) with an approx. 1/16 in hole for flow control. They can be drilled larger if too slow. One per cylinder should suffice. I have a number of them in use on: a front mounted snowblower lift cylinder, a dump cylinder on a 3 pt mixer, a swing cylinder on a 3 pt rake, and a top link for the 3 pt lift.
Unfortunately I have no access to a TSC, but I’ve seen those and I would purchase them if I had access. I can’t seem to find that particular valve in Canada.
ALLMAND LIGHT TOWER (A60736)
ALLMAND LIGHT...
Roto Grind 760 (A60462)
Roto Grind 760...
2025 GPS Trailer (A56858)
2025 GPS Trailer...
2020 FORD F-150 XL EXTENDED CAB TRUCK (A59823)
2020 FORD F-150 XL...
2015 Ford F-350 4x4 Ext. Cab Liberator 3,200LB 1.5 Ton Crane Mechanics Truck (A55973)
2015 Ford F-350...
MACK AUTOMATIC TRANSMISSION (A60736)
MACK AUTOMATIC...
