slow-motion stick welding
/ slow-motion stick welding #2
Was the weldor holding the electrode at the correct distance or long arcing for the sake of the video?
Not sure, but you could try to judge by the electrode size.
BTW, the whole video is less than 1/2 second.
/ slow-motion stick welding #4
In the 1/2 second (real time) video the arc length was closed up significantly. You can see it over the 2 minutes but is real obvious if you drag the slider to speed up the 2 minute slow mo.
/ slow-motion stick welding #5
Looks pretty good to me. Angle about 30-45 deg. Gap (measured to the centerline of the rod) looks OK (about 50% of rod diameter--1/8" dia rod, 1/16" gap). Puddle looks normal. No evidence of long arcing.
2007 Freightliner B2 School Bus (A61573)
2007 Freightliner...
2019 FORD F-150 STX CREW CAB TRUCK (A59823)
2019 FORD F-150...
(4) COLEMAN 60 QUART COOLERS (A64281)
(4) COLEMAN 60...
2021 Peterbilt 389 Sleeper Truck (A62613)
2021 Peterbilt 389...
Ford Golden Jubilee Tractor (A66285)
Ford Golden...
2022 EZ-GO ELITE...
