slow-motion stick welding
/ slow-motion stick welding #2
Was the weldor holding the electrode at the correct distance or long arcing for the sake of the video?
Not sure, but you could try to judge by the electrode size.
BTW, the whole video is less than 1/2 second.
/ slow-motion stick welding #4
In the 1/2 second (real time) video the arc length was closed up significantly. You can see it over the 2 minutes but is real obvious if you drag the slider to speed up the 2 minute slow mo.
/ slow-motion stick welding #5
Looks pretty good to me. Angle about 30-45 deg. Gap (measured to the centerline of the rod) looks OK (about 50% of rod diameter--1/8" dia rod, 1/16" gap). Puddle looks normal. No evidence of long arcing.
iDrive TDS-2010H...
2007 John Deere 1790 Planter (A63111)
2007 John Deere...
2010 CATERPILLAR 320DL RR EXCAVATOR (A60429)
2010 CATERPILLAR...
2017 FORD F-350 XL 35' NON-INSULATED BUCKET TRK (A63276)
2017 FORD F-350 XL...
2023 Kubota BX1880V-1 Sub - Compact Utility Tractor with 54-Inch Mower Deck (A63688)
2023 Kubota...
UNUSED WOLVERINE 60" HYD DRUM MULCHER (A64281)
UNUSED WOLVERINE...
