skidsteer tracks
/ skidsteer tracks #1
simplicityguy92
does anyone think it would be possible to make tracks that fit over the tires on an old bobcat?
/ skidsteer tracks #2
Goodday,
Yes I've seen them built, and used them on bobcat for winter to pull a chipper through the bush. A series of crossbars that cover the tire side to side then extend down the sidewall a short distance. Just like regular snow chains crosslinks/bars but bent solid steel. Then linked togethere with chain, just like the rails on reg chains. Usually more crossbars (to provide floatation) then if needed you can weld (coarks) to the face of bar to add traction.
I've seen solid ones i.e. they are put on with one tire off then the other tire is put in the loop then bolted back on. Or like tipical chain with a claspe of some type.
Hope it makes sense.
/ skidsteer tracks #3
Do you need the tracks or are you just looking for more traction? If just traction a set of tire chains goes a long way.
/ skidsteer tracks #4
hit on search above and type in tracks and rdbrumfield. I posted some pics of tracks I made in 02. I made them for each tire, but it would work for a bobcat too.
/ skidsteer tracks #6
Try searching on craigs list or e-bay. I see them listed once in a while.
2004 Johnson 70hp 4-stroke Outboard Boat Motor (A66738)
2004 Johnson 70hp...
2002 PETERBILT 330 VACUUM BOBTAIL (A67714)
2002 PETERBILT 330...
2008 FORD F150 REGULAR CAB PICKUP TRUCK (A66091)
2008 FORD F150...
MARKER LIGHTS (A64276)
CAT IT28B Cab (A68134)
2001 John Deere 5310 64HP 4WD Loader Utility Tractor (A66734)
2001 John Deere...
