siromer tractors
/ siromer tractors #21
Greg, yes I have done these tests more times than I can remember(been breaking diagnosing and fixing 4X4 for 30 years now). I do this test to the Jinma every time I crawl the chassis looking for loose hardware as it allows me to gauge how tight the front end drive and steering is.
Basic rule of simple/open differentials. with all 3 shafts free(both wheels and drive shaft), spin one, and either of the other 2 can spin depending on drag. Lock one and the other 2 can spin(but in opposite directions). Lock any 2 and the third is also locked.
With the front axle in the air(kinda hard to spin front wheels when they are not:)), and the transfer in 2WD, when you spin one wheel, the torque you are applying ALWAYS takes the path of least resistance. This can be thru the other wheel, or thru the front driveshaft, or both if the drag thru those paths are equal. If you turn one wheel and the other wheel turns in the equal and opposite direction, the driveshaft is NOT spinning. If you block the opposite wheel and again spin the nearest wheel, THEN the driveshaft will spin. If you put the transfer in 4X, then the opposite wheel will ALWAYS turn equal and opposite because the driveshaft is locked. If you block that wheel, NOTHING will rotate. This is a good test to check backlash throughout the entire system. The gearbox being in gear or not has absolutely NO effect on this, just as the clutch use has NO effect on wether 4x will engage or not... Now if you are working on the rear axle, with both the rear wheels in the air, the gearbox being in gear or not makes a difference as in gear the "driveshaft" is coupled to the engaged clutch and the non-rotating engine. With both rear wheels on the ground and blocked(2 differential shafts locked) the rear "driveshaft" is already locked in place so gear selection is irrelevant.
I was bored this afternoon so I made a little Youtube vid below to illustrate this. You will note the gearbox has no effect whatsoever on the response.
Kinda glad i did this as I was doing some heavy brush busting a few months ago and may have damaged my driveshaft housing. The only time the front driveshaft was rotating was when in 2X and the opposite wheel was "coasting". It should have coasted much farther. When I later blocked it in place(shoulda did that in the video:(), the free wheel was very difficult to rotate indicating drag in the driveshaft or transfer case...
[ame]http://www.youtube.com/watch?v=4JkDslBUGIc&context=C34fe9f5ADOEgsToPDskIRgoAFVSGT_oSjzNvrLrfl[/ame]
If i am being a pain Greg, sorry. The old chief in me sneaks out every now and then and he is a real SOB when it comes to technical details:)
/ siromer tractors #22
Video link doesn't work, but no matter. I'm not in a position to make a video of the tests I described anyway. My 4 Chinese geared tractors have been replaced by a John Deere eHydro. The geared tractor drivetrain tests can't be faithfully reproduced on a hydrostatic drivetrain. So at this point in history all I can say is that those tests are a best recollection description of how they worked on my Chinese tractors, and for a few vicinity owners with drivetrain issues of their own (remember all the front end problems in the early days?).
So in the final analysis I guess it's up to our new member from Scotland to try both ways, then determine that which works best for him. Odds are he'll find neither one of us are far off the mark.
//greg//
/ siromer tractors #24
Sorry about that, the link to the video works now. the IPAD2 is great for shooting video and uploading to youtube, but I am having troubles posting links to the video when posting using the ipad. It adds some extra code to the string that I havn't quite got my brain around yet:)
/ siromer tractors #25
We were pretty much singin' off the same sheet of music, right up till you engaged the transmission. I'll admit my recollections have grown fuzzy with age, but - axle lead notwithstanding - I still have memories of my fronts no longer rotating. I've been wrong before, and I'm sure I'll be wrong again. But I hate to leave any stones unturned. So I have to ask. Are you sure your front wheel assist actually works?
//greg//
/ siromer tractors #26
//greg//
Yep, used it 2 weeks ago plowing snow:)
/ siromer tractors
Hi again guys.... Im at a loss as to which type of tractor i have it looks like a Jinma JM-500 two seperate head lights but with the new type grill as that of the Siromer 204S allso cant find any Id Tag No's there are mold No's on engine and transmission cases.....but i have found some No's punch stamped on the engine block at the back of the start motor these go Y---T.*Y.--------A* "the * indicates a five point star and the ----- No's"..Thanks for any info on this
/ siromer tractors #28
Major difference there; the JM500 is a 50hp four cylinder tractor, the Siromer 204S is a 20hp two cylinder tractor. If you want a Jinma comparison, look at the JM204 instead.
//greg//
/ siromer tractors
Hi greg ....Aye its the body work that is puzzling me it looks like the 500 with the two front lights but it has the wrap round grill same as the siromas the safty tags have siromer 07 on them so i take it that it was manufactured sometime after that but i cant find a matching picture of my tractor which was sold to me as a siromer 304..just trying to gather as much info as i can thank you for your comments
/ siromer tractors #31
Clarification please. Is it a 204 or a 304? Makes a big difference. Please post what info you may be able to glean from both the engine label and the tractor label. Engine label is usually on the valve cover or on the side of the block. Tractor label is usually inside one of the fenders or on/alongside the transmission housing. Assuming they're stamped metal, grease tends to obscure the lettering. They'll be easier to read if/when wiped clean with a little WD40 penetrating oil. Pretty sure that's still available in Scotland. Might take some of the black paint with it, but the important thing is to clean out the letter stampings.
If it helps, here's a Siromer 304 being advertised down in Devonshire, and a couple of 204s on eBay; here and here.
//greg//
/ siromer tractors #32
My Siromer is a 204, bought new in 2001. Has had a few issues but nothing too drastic.
2018 Sundowner FD-306 REV A 24ft. T/A Enclosed Gooseneck Trailer (A64194)
2018 Sundowner...
2014 Toyota Tundra Crew Cab Pickup Truck (A64194)
2014 Toyota Tundra...
2024 HITACHI ZW95-6C WHEEL LOADER (A65053)
2024 HITACHI...
2023 VOLVO L90H WHEEL LOADER (A64279)
2023 VOLVO L90H...
2009 Infiniti G37 Coupe (A64557)
2009 Infiniti G37...
2022 EZ-GO ELITE...
