Jinma 354 led headlight bulbs
/ Jinma 354 led headlight bulbs #1
DonRina
Bronze Member
Vancouver Island
Jinma 354
Since I had to order a new fusebox which had the main 30 amp fuse area melted by hot current flow…as well as charging issues I decided to try to lessen the load in the circuit by installing some led headlight bulbs. I ended up getting some with similar dimensioning and bottom alignment slots. I had to remove, metal snip off, the three bulb alignment tabs and just notched out the alignment area similar to the oem bulbs. After that the bulbs slid in place and I reused the tension spring and locking ring.
Cottonbell brand and $30 CDN
H4 LED Motorcycle Headlight Bulb Hi/Lo Beam 4 Sides 360 Degree Upgraded LED Chips Super Bright 6000K White HB2 9003 HS1 P43t Headlamp pack of 2
https://a.co/d/0bM5N5TQ
