Single action cylinder rust prevention
/ Single action cylinder rust prevention #1
Saitcho
Quebec
Kubota B26
Hi guys, I am building a dump bed for a pick-up with a power up gravity down system and I am using a regular cylinder. I will be installing a breather with a filter on the top port but was wondering if I can pour some oil in there to protect against corrosion. I want to pour in a small quantity, extend the ram and whatever stays in will prevent rust. Is that a good idea or will it plug the breather on the long run. Or maybe I can periodically remove the breather and spray some lubricant in there?
/ Single action cylinder rust prevention #2
Crazy brain storming here: What about connecting a hose from the port, directly to the tank, but on the lower side? When the dump bed is going down, it will create vacuum on the cylinder that would pull the fluid from the tank. When lifting the bed, it would just go to the tank naturally. Looks a good rust protection method.
Wont that increase resistance as the dump bed closes?
/ Single action cylinder rust prevention #4
I doubt it would make any difference whatsoever.
Anyway, you can always convert it to a single acting cylinder by removing the piston seals and plug the port you don't need.
The simple breather with a squirt of oil, will probably be more than enough.
2018 KAUFMAN GOOSENECK TRAILER (A63290)
2018 KAUFMAN...
2017 Nissan Altima 4 door (A63689)
2017 Nissan Altima...
2008 MACK CHU613 DUMP TRUCK (A63569)
2008 MACK CHU613...
PALLET FORK MOUNT SAFETY BASKET (A61572)
PALLET FORK MOUNT...
2015 CHEVROLET 2500 HD CREW CAB FLATBED TRUCK (A62130)
2015 CHEVROLET...
2014 Jeep Grand Cherokee 4X4 SUV (A61574)
2014 Jeep Grand...
