Side by Side for yard work 2x4 ok?
/ Side by Side for yard work 2x4 ok? #21
I cannot imagine in the future, lamenting having 4WD as an option. I can definitely imagine wishing for 4WD if you don't.
/ Side by Side for yard work 2x4 ok? #22
We had a small Mule 2WD for a short while - was a pain. Wet grass on a steep hill, it would spin. Going down a steep hill (especially if wet) it would slide unless you gave it the gas so the rear wheels would not lock and slide. Mostly on our hills you don't want to Gas it.
We have had another 6 SxS all 4x4 - never had an issue with any of them and NEVER would even think of getting a 2x4 machine. The little 2WD mule was cheap and I thought it would be fine for the wife to use in the garden. Well, it was but then when she wanted to do other things it would have to be parked so we could get a 4wd machine out so it sort of begged the question of, why have it. Got sold and I can't say I ever missed it.
/ Side by Side for yard work 2x4 ok? #23
I like all wheels driving. (y)
You never see snow or mud?
I see some mud but my soil is mostly sandy loam where I am located. Snow, every once in a while. I figured if I got the side by side stuck I would just get the tractor and pull it out. If I get one it will probably be used not new. Will probably get the 4wd just to know I have it if I need it.
/ Side by Side for yard work 2x4 ok? #25
Put a winch on it. You can pull on other things to get unstuck.
If the side by side is stuck in mud, you may not want to bring a heavier tractor close to try to pull it out.
The winch might be a big help - especially if there is tree nearby. You'll find other uses for that winch as well. Our side by side gets a lot of use. We are on different terrain - nothing but hills and mountains. Would not be without the winch.
/ Side by Side for yard work 2x4 ok? #27
We did look at the Yamaha Warrior or Viking? and considered the Kymco, as well as the JD Gator. Gator we looked at specs for had a top speed of something like 30 mph or so, the Yamaha was wider then we wanted; the Kymco was fine; just didn't know the brand; and push come to shove; I trust Honda engines, and I liked the idea of no belt drive. Polaris, if that belt gets wet, your done till it dries out; but they do have a turf mode.
Honda is known, or was known, for not having sufficient charging for accessories, unless you add a 2nd battery; if that's important for you.
Edit; Don't know if any UTVs/SxSs have the option, but if any come with 120V factory hardwired inverter, that would be Huge. Don't know if the alternators they out in them would support a decent one. If you have a 40 or 50 lbs generator, like the Honda Whisper, might not be an issue; but my generator has too weight 300 lbs with fuel;
Don't the Honda use the same clutch as an old three wheeler? I've heard of problems. Like it ain't enough clutch for real use. My dad bought a belt drive in 07 or 09, thousands of miles per year on the farm. Pulls 16' trailer you can haul a truck on. Still the same belt. I know "if the belt gets wet" , but I ain't never done seen one get wet. They are sealed off. I guess if you swamp it and leave it under water it will eventually get wet. Notice I didn't say a name on the belt drives, just don't knock the belt drive system. I'd much rather swap a belt than pay someone to go internally and rebuild a clutch.
/ Side by Side for yard work 2x4 ok? #28
Let me put it to you this way: Save the money
by not getting the 4X4 and then YOU WILL BE
KICKING YOURSELF IN THE ASS THAT YOU
DIDN'T GET 4X4. BECAUSE YOU NEVER KNOW
WHEN YOU WILL NEED IT!
willy
/ Side by Side for yard work 2x4 ok? #29
He may have a flip flop winch.
/ Side by Side for yard work 2x4 ok? #30
Yes, you will probably regret not getting 4x4 and turf mode.
A few months ago I bought a Polaris Ranger 1000 which has turf, diff lock and 4x4 modes. It can also tow up to 2,500. It's great and very useful. I had a quad for years so the Ranger is the upgrade.
/ Side by Side for yard work 2x4 ok? #32
No, they do not use the same clutch as the 3-wheeler. It is way different as it is a duel clutch system, that basically selects the nest gear before the shift is made. It is a very good system and really has very few problems. The main "issues" have been in the selectors on the Talon and people not being fulling in gear but with proper adjustment, it is corrected. Also, Honda changed a few parts recently to help upgrade the DCT on the Talon (perhaps on the Pioneer but. I am not sure about that).
Belt drives can be fine - Kawasaki is solid, especially on the Mule PRO's, Yamaha has an excellent system. I am personally not a fan of the Can Am or Polaris systems as you see a lot more problems or complaints with them but with more maintenance they will do the job. Seems the utility Polaris/Can-Am holds up better than the RZRs and Mavericks.
/ Side by Side for yard work 2x4 ok? #33
I imagine a used 2wd must be pretty cheap compared to a 4wd one? It sure is a strong negotiating point to knock the price down to something realistic.
If you are buying new, the extra bit that 4wd costs will be worth it at resale time or if you use it off the property. I guess if the main use is as a golf cart or motorized wheel barrow and you are using in mellow terrain similar to golf course, then 2wd should be fine. I find I use my atv to pull stuff and a trailer in the woods and 4wd is required quite often.
/ Side by Side for yard work 2x4 ok? #35
The 4x4 function is best used before you need it.
/ Side by Side for yard work 2x4 ok? #37
That's due to the idiots who buy them to abuse them. I bought my Can-am a couple years ago and immediately began learning what I could about them on the internet forums. The Can-am Defender comes with 27" tires, and that's what the drivetrain was engineered to handle. But it seems that one of the first questions most new buyers ask is "how big a tire can I put on this thing?". Apparently it is possible to fit a 30" tire stock - and some put on portal axles and go a lot bigger. How's this look to you?
And here's how they treat them:
Then a short time later those same idiots are back on the forums bitching because they burned up the belt, twisted off an axle, etc., and saying what a piece of crap Can-am builds. HELLOOOOOO...it was never designed to run 40" tires! And it was never designed to be a submarine!
It seems that Can-am owners are the worst offenders at abusing their machines. I don't see owners of other makes doing this kind of crap. Leave the drivetrain stock, drive it sensibly and it will be trouble free for years.
/ Side by Side for yard work 2x4 ok? #39
Likely because many Maverick and RZRs get flogged pretty hard and some can have double or triple the HP of many utility machines
/ Side by Side for yard work 2x4 ok? #40
I agree DK35vince - the utility machines stick within the design spec for the belt system with room to spare.
All the sport machines get run hard BUT the Can-Am and Polaris seem to favor the high HP which I believe is part of the problem. This is where the belts become the weak spot and cause issues. All brands have people running larger tires, and even portals so that normally is not the whole problem. I run 4" larger tires on our one Honda and it caused zero issues. Why, because the machine is not run hard and Honda over designed the parts to allow for larger tires (they knew most people oversize the tires).
Portals normally reduce the gear ratio so that does help offset the larger tires being used on those machines to some extent. Well within reason that it. Generally speaking, Yamaha and Kawasaki have a slightly better-designed and more durable belt/clutch system. Honda skipped the belt and went with a duel clutch and gear system. It still has some quirks but overall is a solid design.
Anytime you design an off-road vehicle and sell it, you need to account for the "idiot factor" - you know that guy, the one that uses it as a submarine or low-flying aircraft. Some companies account for the "idiot factor" a little better than others. All the machines are fine if used within their design specs, but when they get pushed is when the weakness starts to quickly show.
2012 FOREST RIVER 24' T/A ENCLOSED TRAILER (A65643)
2012 FOREST RIVER...
2000 FORD F-550 XL SUPER DUTY DUALLY SERVICE TRUCK (A60430)
2000 FORD F-550 XL...
17601CFL (A59228)
17601CFL (A59228)
Purdy PT 60' Land Leveler (A64126)
Purdy PT 60' Land...
NEW Wolverine ADB-13-1218R, Skid Steer Auger (A62679)
NEW Wolverine...
ATTENTION PLEASE READ (A64126)
ATTENTION PLEASE...
