Shuttle Shifter issues
/ Shuttle Shifter issues #21
Hi all, hope one of you can help me.
I have a 1994 555D Ford backhoe and when I have been using it anywhere from 20-30 min the shuttle shifter stops working and it won’t go forward or reverse. After it cools down it can be used again…. What is causing this? It’s a real pain and can’t get much work done…. Any help or advice would be greatly appreciated.
Thank you!
may be a clogged hydraulic filter. I would do a Hydraulic service to it
/ Shuttle Shifter issues #23
Welcome to TBN.
When it does this, it won't even try to move?
If you lift the back end off of the ground and engage the shuttle, do the wheels move or try?
might check the transmission fluid and some tractors have to be filled a certain way or air gets in and causes it not to work,,,
When the back end is lifted off the ground it will not move. I will have him check fluid again. Thanks!!
/ Shuttle Shifter issues #26
The transmission oil is independent of the rear end oil and the hydraulic system. The transmission filter is the one on the LH side of the transmission.
Just wanted to give everyone an update to the issue I was having with the shuttle shifter. It turned out to be the battery. We replaced the battery and now we are having no issues with the shifter. Thank you all for your help and ideas.
/ Shuttle Shifter issues #28
Kris you had me wondering. Thanks for the update and I find it very difficult to understand
/ Shuttle Shifter issues #29
That's interesting. I would not have expected that to be the problem at all.
@ Mike & eKretz I don’t understand it either. Our neighbor works for the county and he told my son it was the battery so we had tried everything else so why not. Makes no sense to me either.
SET OF (10) ACE CATTLE PANELS W/CONNECTION JOINTS (A60736)
SET OF (10) ACE...
SKIDDED FRAC TANK (A58214)
SKIDDED FRAC TANK...
2012 MACK CHU (PINNACLE) (A60736)
2012 MACK CHU...
204158 (A57193)
204158 (A57193)
LAYMOR BOOM SM300 (A60736)
LAYMOR BOOM SM300...
2025 MMS MS36C (A60463)
2025 MMS MS36C...
