shutdown vs leave running
/ shutdown vs leave running #11
Well, I have to agree with the 10 minute or less rule too. I know my Dodge Cummins manual even goes so far as to recomend 1-6 minutes (depending on how hard your working it) of idle time after running to cool down. It also recomends avoiding periods of extended idling. (due to carbon build up) It is especially important if you are running a turbo unit to give it a cool down period so the cooler oil can cool those turbo charger bearings down a few degrees. I also normally let my tractor run at about 1200 RPM while performing other tasks for a couple minutes rather than shutting down. And just like someone else mentioned - it makes people think your just a workin' fool. That is especially important to get your wife thinking that's the case. /w3tcompact/icons/wink.gif
Troy
/ shutdown vs leave running #12
Troy,
I don't know about the dodges but the fords come with what they call an auxillary idle controller that you can program to change your idle speed every x minutes and you can program it to turn off after the turbo is cooled down. Pretty nice feature and avoids the hot turbo and carbon buildup that you talked about.
/ shutdown vs leave running #13
Cowboydoc
Unfortunatly the Dodges don't come with those features. (at least my old 2000 didn't) I know that you can buy a programable timer to shut it down after x minutes at genosgarage.com. I have thought about it a few times but elected not to spend the $$ on it. I just wait with the truck or let 'r run.
Troy
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2019 CATERPILLAR 326FL EXCAVATOR (A60429)
2019 CATERPILLAR...
2021 Unverferth 432 Rigid 4 Row 36-inch 3PT Ripper Bedder (A61307)
2021 Unverferth...
CAT CB34 (A60462)
CAT CB34 (A60462)
2019 Chevrolet AWD Equinox SUV (A59231)
2019 Chevrolet AWD...
2000 ITASCA SUNCRUISER 37G CLASS A RV (A58214)
2000 ITASCA...
