Shut Down Problem
/ Shut Down Problem #1
Bob85355
Maricopa County, Arizona
Yanmar 1500
Used to be a decent gas engine mechanic back in the 50's and 60's. Don't know much about diesels. Have owned a YM 1500 for 10 years. Engine block cracked this year and had a local outfit find another engine, rebuild it and its running great. If fact, it don't know when to quit. Push the throttle lever as far as it goes will bring the RPM down to 300 to like an old HIT & MISS. But it don't stop running. My understanding is that the throttle is supposed to cut off the fuel flow thus stopping the enfine. Will adjusting the throttle rod solve this problem or is there something else that should be done.
TIA
Bob
Central Arizona
/ Shut Down Problem #2
reach down and pull the lincage shut that your lever hooks too. this is the linkage that goes to the injector pump. the spring is weak.
/ Shut Down Problem #4
I just have a habit of pulling the linkage shut with my hand after i dismount the tractor and it idles for a few seconds or mins to cool off. I hold the throttle and push it as i pull the linkage to the pump by hand. May sound like a pain to some but its second nature now.
/ Shut Down Problem
Thanks to all who responded. Its good to be on Tractor By Net and a part of the Yanmar family.
Bob
/ Shut Down Problem #7
Go Sheriff Joe! :thumbsup: Welcome to the forum btw!
2022 DODGE RAM 2500 (A65643)
2022 DODGE RAM...
90in. Work Bench (A65640)
90in. Work Bench...
2002 EZGO Electric Cart (A64557)
2002 EZGO Electric...
2015 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A64194)
2015 Peterbilt 567...
Kubota L175 Tractor (A62613)
Kubota L175...
2015 Ford Transit Connect Van, VIN # NM0LS7E74F1193985 (A65563)
2015 Ford Transit...
