sixdogs
Super Star Member
- Joined
- Dec 8, 2007
- Messages
- 15,809
- Location
- Ohio
- Tractor
- Kubota M7040, Kubota MX5100, Deere 790 TLB, Farmall Super C
Here's an idea for anyone with a 3 pt. rototiller . The problem is stuff like twine and grass gets tightly wound up in the tines and is extremely difficult to remove. The solution was to find a tool with a hooked edge that would get between the tight grass or twine at the correct angle to get the obstruction out. I couldn't find anything so I made this...
The photos came out in reverse order--duh on my part--but it's an old sledge handle cut down and a hooked blade I bought inserted in a slot I made with a thin blade on my tablesaw . I think I got the blade from Smoky Mtn Knife Works. Anyway, the blade is fairly thin as blades go and has a tapered and hooked tip to it. Made in Austria. Most important, I mounted it at a slight angle--see photos-- so it clears obstructions like tiller tines and yet the tip is pointed and sharp enough to rip out tightly wound grass in mere moments. Same with twine or whatever.
What used to take a half-hour now takes 15 seconds and I can use that time for other pursuits. Heck, it works for me.
