Should I grease it?
/ Should I grease it? #11
I would consult your local dealer or call JD direct and find out the corect answer.
It is possible that they changed bearing types and did not update the manual.
Or, have the bearings ever been changed?
just my $.02.
/ Should I grease it? #12
<font color=blue>But still, why do they put fittings on the spindles? What's the rationale?</font color=blue>
Ya got me there! I have no idea, unless as cj7 mentioned, they changed the design at some point. On the bright side, if the bearings blow out, with a zerk you have the option of going to a greasable bearing here (assuming the zerk actually connects to something that lets grease into the bearing).
John Mc
Well I called my dealer and asked him about the grease zerks. According to JD the spindles have sealed bearings and the zerks are used at the factory to ease the assembly process and additional grease would have no beneficial effect. However, overgreasing "could lead to premature failure of the sealed bearings". He recommended that I not grease them.
/ Should I grease it? #14
Well, this seems to be the definitive answer. Thanks Pitbull!
1982 SHOP BUILT GOOSENECK 24 FT TRAILER (A58214)
1982 SHOP BUILT...
EZ-GO Electric Golf Cart (A60462)
EZ-GO Electric...
Case SV280B (A60462)
John Deere 8R 280 (A60462)
John Deere 8R 280...
2013 Ram 5500 Bucket Truck, VIN # 3C7WRNALXDG552597 (A61165)
2013 Ram 5500...
2023 FORD F750 CAB & CHASSIS (A57880)
2023 FORD F750 CAB...
