ArlyA
Super Star Member
- Joined
- Mar 18, 2016
- Messages
- 14,580
- Tractor
- Outlander1000 6x6, Ego lawn mower and shopping for tractor
I'm still hoping someone here who has added axles to their shipping container would post pics.
As does a following escort with the 4 way flashers on.Yes, a tractor and a SMV sign for short hauls avoid much of the hassles.
What's wrong with the set up you pictured?I'm still hoping someone here who has added axles to their shipping container would post pics.![]()
I like trailers with suspension for use on the road.What about just using a farm wagon running gear? That would be the simplest in my mind.
Nothing,. I like what these fellows did with there container trailer.Arly I don't see anything wrong with the set up you pictured. You said that it would be empty for transport, the long sub frame for the axles and suspension will distribute the load of the box to multiple floor cross members (very close to the sides) and are just shy of being centered leaving not much tongue weight or work to do other than guiding the now trailer.
This company has springs for the wagon up to 6,000lbs. Although I have pulled many of them on the roads without issues. Even pulled one from Mississippi all the way to Florida.I like trailers with suspension for use on the road.
I sure don't like backing those steering axles trailers up! Seems putting some axles slightly behind center is the easiest way to go and that style trailer is easy to back up.This company has springs for the wagon up to 6,000lbs. Although I have pulled many of them on the roads without issues. Even pulled one from Mississippi all the way to Florida.
Farm Wagon Bed Bolster Springs
Farm wagon bed bolster spring set of four adds extra spring suspension to most makes of farm wagons with tubular frame axles. Assemblies secure the bed of a farm wagon, providing spring suspension and reducing tipping on hilly ground or when turning sharply with heavy loads. Widely used by the...cottagecraftworks.com
Yikes! I think I'll take your advice when I see one in the future.Reading through the post reaffirms my policy of when you see someone towing a trailer on the highway today, get as far away from them as possible.
Do you have pics? We will use springs and hangers.I just used mobile home axle under mine if you want to get fancy you can use the springs and hangers![]()
Is this for highway use, or for simply moving the container - slowly - down some back road?Gee guys,. Building trailers is not a black science or thoery
It will of course have tongue weight, like most trailers and no need for jacks (other than its hitch)I personally like the idea and hope to see what you come up with. Things like springs and brakes are just options and personal preference for the intended use.
I liked the running gear idea because it would be solid when parked and no need for jacks. Also no tongue weight to worry about. But I also can back one with no issues and have pulled many configurations on the roads. I do understand the reasons why Arly would rather build it the way he wants.
