Shibaura Oper Manuals
   / Shibaura Oper Manuals #11
SHIBAURA SD Series
  • SHIBAURA SD1500 SD1540B.pdf
  • SHIBAURA SD2403 SD2443 SD2603 SD2643.pdf
  • SHIBAURA SD3203 SD3243 SD3903T SD3943T SD4003 SD4043 SD4603T SD4643T.pdf
  • SHIBAURA SD4000A SD4000AD SA4000A-O SA4000AD-O.pdf
  • SHIBAURA SD4300 SD4340 SD4500 SD4540 SD5000T SD5040T.pdf
  • SHIBAURA SD4300 SD4340 SD5000T SD5040T OPS MANUAL.pdf
   / Shibaura Oper Manuals #12
SHIBAURA SE Series
  • SHIBAURA SE5300 SE5340 SE6300 SE6340 SE7300T SE7340T.pdf
  • SHIBAURA SE5306 SE5346.pdf
  • SHIBAURA SE7300 SE7340 SE7900 SE7940 SE8300 SE8340 SF1000T SF1040T.pdf
   / Shibaura Oper Manuals #13
SHIBAURA SP Series
  • SHIBAURA SP1400 SP1440 SP1800 SP1840 SP2100 SP2140.pdf
  • SHIBAURA SP1500 SP1540 SP1700 SP1740 SP1540LC SP1740LC Parts Manual.pdf
  • SHIBAURA SP2500 SP2540 SP2540PL.pdf
  • SHIBAURA SP4500 SP4540 SP5500 SP5540.pdf
   / Shibaura Oper Manuals #14
This is awesome work!
New member here, just acquired a Shibaura P21F and hoping you might be able to find manuals for that also? I looked at the P series manuals listed here but those models are quite different.
   / Shibaura Oper Manuals #15
The P21F is a rare model, but the engine is popular. It's common as the P19 & P21 model with the same engine. Just the fuel pump and injectors are different to boost the Hp from the P19 model to the P21.
The Ford 1520 & 1715 have the same engine, J843. You could look for manuals for the Ford1520 to get the info you need. Other documentation shows the Ford 1620 & 1630 use the same engine as well.
There is very limited info on the web for your machine. For a US supplier of manuals, look here,
Parts Manual - Shibaura P19, P21
I used all of my backdoor ways to find any info and free PDF manuals, yet nothing even showed up.
CM284 uses the SAME engine, J843. I did locate the Service Manuals for it. :)
This way you can glean enough info to help you get started.
https://tractormanualz.com/wp-content/uploads/2019/01/Shibaura-Front-Mover-cm284-j843-engine-workshop-manual.pdf
https://s0c7493e4ee454f97.jimcontent.com/download/version/1622373765/module/16014011922/name/Shibaura%20CM284%20Front%20Mower%20Engine%20Workshop%20Manual%20PDF.pdf
Now, the Ford 1520 uses the same engine as well.
https://pruefberichte.dlg.org/filestorage/FORD_1520_Nr1139_1988-englisch.pdf
   / Shibaura Oper Manuals #16
I do have more manuals, yet there is a max of 7.98Mb limit to attach files here.
   / Shibaura Oper Manuals #17
Thanks much for the info, I actually just bought the Ford I&T shop manual off ebay and it arrived today.
The manuals you have that are too big, are they pertaining to my tractor or is that info general for the thread?
   / Shibaura Oper Manuals #18
Also, any chance of an operators manual for a similar Ford? It's so odd, my tractor appears to be most similar to a 1715 then? The 1720 looks similar also but maybe not so much?
   / Shibaura Oper Manuals #19
I have a few limited manuals for the Shibarua Ford models. They are too large to attach to this site.
Also, I have a few more manuals to add here for tractors and tillers.
   / Shibaura Oper Manuals #20
the only English operator or repair manuals are for the Fords, I can supply the closest manuals & Japanese/English parts books
80in HD Tooth Bucket with Side Cutters (A52748)
80in HD Tooth...
2017 VOLVO VNL SLEEPER (A52577)
2017 VOLVO VNL...
2008 Nissan Sentra Passenger Car (A51694)
2008 Nissan Sentra...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
Generac 5000Watt Heavy Duty Diesel Generator (A51691)
Generac 5000Watt...
2012 RAM 5500 (A52472)
