Shibaura Oper Manuals
   / Shibaura Oper Manuals #11
SHIBAURA SD Series
  • SHIBAURA SD1500 SD1540B.pdf
  • SHIBAURA SD2403 SD2443 SD2603 SD2643.pdf
  • SHIBAURA SD3203 SD3243 SD3903T SD3943T SD4003 SD4043 SD4603T SD4643T.pdf
  • SHIBAURA SD4000A SD4000AD SA4000A-O SA4000AD-O.pdf
  • SHIBAURA SD4300 SD4340 SD4500 SD4540 SD5000T SD5040T.pdf
  • SHIBAURA SD4300 SD4340 SD5000T SD5040T OPS MANUAL.pdf
   / Shibaura Oper Manuals #12
SHIBAURA SE Series
  • SHIBAURA SE5300 SE5340 SE6300 SE6340 SE7300T SE7340T.pdf
  • SHIBAURA SE5306 SE5346.pdf
  • SHIBAURA SE7300 SE7340 SE7900 SE7940 SE8300 SE8340 SF1000T SF1040T.pdf
   / Shibaura Oper Manuals #13
SHIBAURA SP Series
  • SHIBAURA SP1400 SP1440 SP1800 SP1840 SP2100 SP2140.pdf
  • SHIBAURA SP1500 SP1540 SP1700 SP1740 SP1540LC SP1740LC Parts Manual.pdf
  • SHIBAURA SP2500 SP2540 SP2540PL.pdf
  • SHIBAURA SP4500 SP4540 SP5500 SP5540.pdf
   / Shibaura Oper Manuals #14
This is awesome work!
New member here, just acquired a Shibaura P21F and hoping you might be able to find manuals for that also? I looked at the P series manuals listed here but those models are quite different.
   / Shibaura Oper Manuals #15
The P21F is a rare model, but the engine is popular. It's common as the P19 & P21 model with the same engine. Just the fuel pump and injectors are different to boost the Hp from the P19 model to the P21.
The Ford 1520 & 1715 have the same engine, J843. You could look for manuals for the Ford1520 to get the info you need. Other documentation shows the Ford 1620 & 1630 use the same engine as well.
There is very limited info on the web for your machine. For a US supplier of manuals, look here,
Parts Manual - Shibaura P19, P21
I used all of my backdoor ways to find any info and free PDF manuals, yet nothing even showed up.
CM284 uses the SAME engine, J843. I did locate the Service Manuals for it. :)
This way you can glean enough info to help you get started.
https://tractormanualz.com/wp-content/uploads/2019/01/Shibaura-Front-Mover-cm284-j843-engine-workshop-manual.pdf
https://s0c7493e4ee454f97.jimcontent.com/download/version/1622373765/module/16014011922/name/Shibaura%20CM284%20Front%20Mower%20Engine%20Workshop%20Manual%20PDF.pdf
Now, the Ford 1520 uses the same engine as well.
https://pruefberichte.dlg.org/filestorage/FORD_1520_Nr1139_1988-englisch.pdf
   / Shibaura Oper Manuals #16
I do have more manuals, yet there is a max of 7.98Mb limit to attach files here.
   / Shibaura Oper Manuals #17
Thanks much for the info, I actually just bought the Ford I&T shop manual off ebay and it arrived today.
The manuals you have that are too big, are they pertaining to my tractor or is that info general for the thread?
   / Shibaura Oper Manuals #18
Also, any chance of an operators manual for a similar Ford? It's so odd, my tractor appears to be most similar to a 1715 then? The 1720 looks similar also but maybe not so much?
   / Shibaura Oper Manuals #19
I have a few limited manuals for the Shibarua Ford models. They are too large to attach to this site.
Also, I have a few more manuals to add here for tractors and tillers.
   / Shibaura Oper Manuals #20
the only English operator or repair manuals are for the Fords, I can supply the closest manuals & Japanese/English parts books
2015 FREIGHTLINER SPRINTER VAN (A52576)
2015 FREIGHTLINER...
(1) HD 27ft x 24ft Full Garage Kit Metal Building Frame (A51573)
(1) HD 27ft x 24ft...
Electric Mobility Scooter (A51694)
Electric Mobility...
2015 International DuraStar 4300 26ft. Box Truck (A51692)
2015 International...
JOHN DEERE 8R 280 LOT NUMBER 7 (A53084)
JOHN DEERE 8R 280...
Tires (A50322)
Tires (A50322)
