Sheep Handler
/ Sheep Handler #1
stephan
NSW, Australia
Lamborghini 450 Runner, SAME Tiger 70, Kioti CS2610
I bought this the other day for AUD$350. It's about 16 feet long and 10 foot high. Now I'm in the process of renovating it with a new coat of paint and some stragically placed grease.
Side view.
/ Sheep Handler
It uses a hydraulic cylinder to pull cables that lift the centre cradle.
Cradle
/ Sheep Handler
Cables
/ Sheep Handler
Cable adjustment and lever action.
/ Sheep Handler
End.
/ Sheep Handler
Here is the cylinder. Can someone tell me the best way to "recondition" a hydraulic cylinder?
/ Sheep Handler
I've been using this to remove the rust and old paint. Very tiring work on the arms and a bit dangerous when it kicks back.
/ Sheep Handler
Progress so far. Nice shade of blue. I reckon the goats will love it.
/ Sheep Handler #9
Extend cylinder and look for schratches. If is ok then just wash it inside with diesel fuel on both piston sides, 2-3 times, and connect to hydraulics. Then try it for leaks on rod outgoing side. I assume that cylinder hasn't bent rod.
Usually that's enough, and if no, replace seals.
Hope this helps.
/ Sheep Handler #10
Is that thing for trimming feet or what is the purpose for lifting it up? I've seen pictures of the tapered conveyors for handling sheep but not anything like this. By the way if you could point me toward any websites for sheep handling equip I'd appreciate it. I've googled but sometimes the keywords might not catch some companys.
/ Sheep Handler
Yep for trimming the feet but when there are a few inches off the ground they are real easy to drench.
Try searching au.yahoo.com
2015 Chevrolet Impala Sedan (A64557)
2015 Chevrolet...
TIMBERJACK 225E CABLE SKIDDER (A64277)
TIMBERJACK 225E...
1978 Fruehaue Chipper Trailer (A62613)
1978 Fruehaue...
2026 DEVELON DX27Z-7 EXCAVATOR (A64279)
2026 DEVELON...
Skid Steer Blank Plate (A65640)
Skid Steer Blank...
John Deere 785 Manure Spreader (A66408)
John Deere 785...
