Shed? PT Attachment? Both!
/ Shed? PT Attachment? Both! #1
BobRip
Elite Member
Powhatan Va.
2000 Power Trac 422
I have been wanting a shed, basically a roof, to keep rain off of my thirty gallon gas tank. Recently after hurricane Irene, I could not run my generator until the rain stopped. I wanted to build a generator shed near the house, but the wife has a limit of two outbuildings on the property, and I have three. She does not mind if they are down in the woods. After much thought I consider making a very small shed to cover the generator. This would be something I could move easily. I realized that the Power Trac could move it. So I made a shed that has a boom pole going through it. I can connect the boom pole through the two inch receiver quick attach plate. Now I store the gas tank in it most of the time and move it to near the house right after a storm, if needed.
What weird things have you put a quick attach plate on?
/ Shed? PT Attachment? Both! #3
Wow you have me beat!
I never thought to hook up a building to my PT. :laughing:
Say, if you reinforce the bottom edge of your shed, you could us it to back blade your drive way and smooth it out. Make it a multi tasker. :)
/ Shed? PT Attachment? Both! #4
I was thinking about putting one on the trash can if we can ever afford to move to our rural property. The driveway will be 400' +-. Then I found out the QA male on the tractor fits under the rim nicely, so it isn't needed. :laughing:
/ Shed? PT Attachment? Both! #5
Been thinking about building a fuels / combustible storage shed out of adobe. I figure the 12" wall would help moderate hot / cold temps and with the masonry building it would be fire proof as well.
This would keep propane, gasoline, paint & chemicals out of the garage / house and make these spaces safer.
Still trying to fit the shed onto the property within the setbacks, close enough to be handy; far enough away to be safe. This will require at least 8 more beers - and no, I'm not staggering around the place, I'm taking measurements.
tim
tim
Sound good, but have some ventilation.
/ Shed? PT Attachment? Both! #7
I saw a tv show about building w/adobe a while back. I was surprised they didn't use any straw just a mix of clay, sand and some cement and water that they put into large brick shaped forms. After what seemed like a pretty long curing time, they used the same mix as mortar. I think the company was called Adobe Building Consultants.
I thought about building a low retaining wall w/adobe but haven't got to that project yet. :)
Good luck and be sure to tell us how it goes
/ Shed? PT Attachment? Both! #8
Can you use adobe in areas of high rainfall? Wet and freeing sounds like it would be even worse. West Cascades of Washington State sounds wet.
Ken
/ Shed? PT Attachment? Both! #9
is the shed hurricane rated? :laughing: It might be ripped to shreds before you had a chance to use it.
No, it is not hurricane rated, and that concerns me. My rational (weak as it is) is that I live in a valley and the shed is in a thickly wooded area. This should help shield it from wind. Also I do have some pieces of rebar bent to L shape nailed in the ground to help hold it down. Right now they are too short and I can pull them out too easily. My plan is also to run a rope over the roof and tie it down to trees during a storm.
/ Shed? PT Attachment? Both! #11
Ken
I think the added cement might help. I have seen a few things on the internet that indicate that there has been some adobe but im not sure if there are any specific things done to make it successful though.
/ Shed? PT Attachment? Both! #12
Ken
Yes you can. Use Stabilized Adobe, with cement (about 6-8% by weight) or asphalt emulsion (about 5% by weight). This makes the sand / clay mix waterproof. Also you can coat the block with a lime plaster to protect it from rain.
I make Compressed Earth Brick with a cement stabilization that holds up pretty good. I have one in a 5 gal bucket covered with green moss that is strong.
anyone interested in this material can PM me for a longer discussion
tim
2018 Bobcat S-570 (A63689)
2018 Bobcat S-570...
2017 CATERPILLAR 980M WHEEL LOADER (A62129)
2017 CATERPILLAR...
1068 (A63291)
1068 (A63291)
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
2007 JLG E400AJP TELESCOPIC/SCISSORING MANLIFT (A52709)
2007 JLG E400AJP...
2006 Toro SandPro 2020 Bunker Rake (A61572)
2006 Toro SandPro...
