Shear pin (bolt)
/ Shear pin (bolt) #1
Milbrand1951
Aiken, SC
John Deer 1000 series
On my JD 1023e tractor, the drive-line shield guard on the Frontier rotary cutter sits atop the shear pin which I need to change because it keeps breaking. I am probably not using the correct shear bolt which I plan on correcting. In the manual it says to bend back driveline shield cone. How do I do this? It is kind of awkward trying to tighten the bolt with the shield guard in the way. Would appreciate any help on this. Do I need to un-fasten the shield cone to do this? Surely someone out there has had to replace a shear bolt on a Frontier cutter.
/ Shear pin (bolt) #2
When these guards get in the way I modify or remove them.
larry
/ Shear pin (bolt) #3
larry
+1 Can you simply cut away a bit of the guard(I assume it's the wide part over the universal joint) with tin snips? I had to do that for my snowblower.
/ Shear pin (bolt)
Yeah, thanks. Several other people advised me to do the same thing.
2022 YANMAR VIO55-6A EXCAVATOR (A63276)
2022 YANMAR...
2017 Kubota M7-151 Premium MFWD Tractor (A61307)
2017 Kubota M7-151...
Wolverine TL-12-72W 72" Skid Steer Tiller (A62679)
Wolverine...
11in. Bucket w/ Teeth Excavator Attachment (A64194)
11in. Bucket w/...
2010 KEYSTONE LAREDO (A65643)
2010 KEYSTONE...
Wooden Indian Statue (A64127)
Wooden Indian...
