Shear pin (bolt)
/ Shear pin (bolt) #1
Milbrand1951
Aiken, SC
John Deer 1000 series
On my JD 1023e tractor, the drive-line shield guard on the Frontier rotary cutter sits atop the shear pin which I need to change because it keeps breaking. I am probably not using the correct shear bolt which I plan on correcting. In the manual it says to bend back driveline shield cone. How do I do this? It is kind of awkward trying to tighten the bolt with the shield guard in the way. Would appreciate any help on this. Do I need to un-fasten the shield cone to do this? Surely someone out there has had to replace a shear bolt on a Frontier cutter.
/ Shear pin (bolt) #2
When these guards get in the way I modify or remove them.
larry
/ Shear pin (bolt) #3
larry
+1 Can you simply cut away a bit of the guard(I assume it's the wide part over the universal joint) with tin snips? I had to do that for my snowblower.
/ Shear pin (bolt)
Yeah, thanks. Several other people advised me to do the same thing.
1984 Mack MS250P Fuel Truck, VIN # VG6M114B1EB080951 (A65563)
1984 Mack MS250P...
2016 INTERNATIONAL PROSTAR+122 6X4 ROAD TRACTOR (A65054)
2016 INTERNATIONAL...
Skid Steer Blank Plate (A65640)
Skid Steer Blank...
Multipurpose Skid Steer Mount Backing Plate  (A62679)
Multipurpose Skid...
Stout Buckets HD78-3 Rock Bucket Skid Steer Grapple (A65640)
Stout Buckets...
TR 23 QA Mini Trencher (A64127)
TR 23 QA Mini...
