Shear pin (bolt)
/ Shear pin (bolt) #1
Milbrand1951
Aiken, SC
John Deer 1000 series
On my JD 1023e tractor, the drive-line shield guard on the Frontier rotary cutter sits atop the shear pin which I need to change because it keeps breaking. I am probably not using the correct shear bolt which I plan on correcting. In the manual it says to bend back driveline shield cone. How do I do this? It is kind of awkward trying to tighten the bolt with the shield guard in the way. Would appreciate any help on this. Do I need to un-fasten the shield cone to do this? Surely someone out there has had to replace a shear bolt on a Frontier cutter.
/ Shear pin (bolt) #2
When these guards get in the way I modify or remove them.
larry
/ Shear pin (bolt) #3
larry
+1 Can you simply cut away a bit of the guard(I assume it's the wide part over the universal joint) with tin snips? I had to do that for my snowblower.
/ Shear pin (bolt)
Yeah, thanks. Several other people advised me to do the same thing.
UNUSED WOLVERINE GB-11-72W 72" HYD GRAPPLE BUCKET (A62131)
UNUSED WOLVERINE...
New/Unused CFG Industrial QH12R Mini Excavator (A61166)
New/Unused CFG...
CATERPILLAR T40D STRAIGHT MAST FORKLIFT (A62129)
CATERPILLAR T40D...
22" PIN-ON EXCAVATOR BUCKET W/PINS (A60429)
22" PIN-ON...
iDrive TDS-2010H...
2024 COLEMAN MINI BIKE (A58375)
2024 COLEMAN MINI...
