Shear bolt... from what?
/ Shear bolt... from what? #1
ning
Elite Member
Northern California
Branson 3520h
I was using a phd on my Branson 3520h, and I hit a big rock and saw part of a bolt fly away; if I recall, the phd stopped spinning.
Strange thing is, it wasn't the bolt holding the auger on; the snapped bolt is much smaller (like a 3/8" head, with a washer), and when I went to swap to my scraper blade, I could swear the phd was spinning when I engaged the pto on a lark.
What bolt did I snap? I don't see any missing anywhere.
/ Shear bolt... from what? #2
Driveshaft shear bolt, may still have a piece in there catching enough to turn auger not in ground
/ Shear bolt... from what? #3
That large bolt holding the auger on is probably a set screw with a rounded end that sits in a groove in the auger shaft. It keeps the auger from falling out, when the shear bolt shears but lets the pto spin without engaging the auger. Replace the shear bolt and you should be good to go. You will have lost the head and the other end of the shear bolt with the nut on it, but the main part of the shear bolt will still be in the auger shaft. Align the shear bolt holes and punch it out.
/ Shear bolt... from what? #4
On the PTO shaft closest to the gear head. That's the one I shear all the time.
Thanks all, on closer inspection of the PTO shaft I did indeed find a missing bolt:
Thanks for the solved mystery, and I'm glad it's not something unexpected... and that I'll be able to replace it so I can use the PHD next time I want to!
/ Shear bolt... from what? #6
Now... what's up with all the oil over the gear box??? :D :D :D ...or am I seeing it wrong?
Actually had a friend say... "It's a tractor, it's suppose to leak oil..."
/ Shear bolt... from what? #7
It looks like a high-gloss paint job to me.
Steve
/ Shear bolt... from what? #8
I think that's just gloss paint on any uneven surface.
/ Shear bolt... from what? #9
It looks like glossy paint to me. Then not there to wipe with my finger to be sure. lol
Yep it's mostly clean, just a bit of dust.
Now the rest of the tractor on the other hand... let's just say I need to buy a pressure washer, stat.
19 gal Portable Sandblasting Cabinet (A66408)
19 gal Portable...
2003 Odyssey Lextra 2502 Pontoon w/ 2009 Bagg Boat Trailer (A62613)
2003 Odyssey...
Mini Excavator Rake Attachment (A64127)
Mini Excavator...
2024 Bobcat T650 (A64126)
2024 Bobcat T650...
New/Unused AGT Industrial SDA-140W Mini Wheel Loader (A65583)
New/Unused AGT...
40' New Container (A62679)
40' New Container...
