Mowing sharpening finish mower blades
/ sharpening finish mower blades #1
2516mo
Missouri
2010 mahindra 2516 gear
I have never been very good at sharpening mower blades. I can get them sharpened for 9.00 each times 3, but its 30 minutes each way, after removing them, and waiting a week each time. I have been looking at the dedicated machines which start at a 199.00. Just wondering if they are worth it. I realize that I could get a lot of sharpening done for 200.00, but the sharpener is intreaging. An alternative I am considering is getting a second set of blades again, and keep a sharp pair in the garage.
Advice please?
/ sharpening finish mower blades #2
I use either an angle grinder with about a 120 grit disk, or my 3" belt sander with a 100 grit belt. Either works great for me. I use a single cut ******* to remove the burrs.
I've also used a 2" vertical belt sander in the past that also worked well. Just be sure to avoid overheating the blade.
Have two sets of blades so you have a sharp set on the shelf, then you can sharpen the dull ones at your leisure
/ sharpening finish mower blades #3
Ditto
Belt / disc sander is the bees knees for sharpening blades.
/ sharpening finish mower blades #4
For something like a chainsaw, where there are all those little teeth to deal with, and consistency is critical, I could kind of see getting a dedicated cutting machine. But for a mower I don't think a dedicated machine is warranted. For one thing, the shape of the blade is pretty simple--and for another thing... I mean, call me a heretic if you will... but I don't think the consistency of the blade's edge is that critical. We're not talking about a sushi knife here! I sharpen my mower blades by hand, with either a bench grinder or a hand-held angle grinder. Just look at a fresh blade to get an idea what angle you're shooting for and then have at it.
/ sharpening finish mower blades #5
Advice please?
Yes a dedicated machine is worth it. Its not just getting it sharp its getting the correct angle too 30° and to take it a step further getting them balanced and not on the old fashioned cone style. I have a dedicated machine and if my blades aren't to bad I can have them off sharpened and back in 10min balanced takes 15min if its not out to far
/ sharpening finish mower blades #6
I sharpen mine myself as others mention but before I spent an extra $200 on the tool I would buy a few sets of blades that way you bring several sets of blades in when it is convenient.
/ sharpening finish mower blades #7
The "special" tool is just a grinder with a table to rest the blade on, the table just has to be the right hight.
/ sharpening finish mower blades #8
When you're sharpening mower blades, don't forget to balance them before you re-install them. Also, they aren't sharpened to a razors edge, they are purposely left with a 1/16" blunt edge so they don't break.
2025 Pabreak 80in. Bucket Skid Steer Attachment (A61567)
2025 Pabreak 80in...
2021 Topcat SSSTG200 Stump Grinder (A62679)
2021 Topcat...
SCAN TO RECEIVE TEXT UPDATES (A64277)
SCAN TO RECEIVE...
New/Unused Landhonor 26ft x 13ft Metal Carport (A65583)
New/Unused...
2011 FORD F-150 (A65643)
2011 FORD F-150...
Angle Broom (A64126)
