servicing the 7040
/ servicing the 7040 #1
bigbull338
Elite Member
texas
7040 HDC 1153 fel
finally going to change the oil an filter on the 7040su if time permitts today.going to change the oil an filter.it had 10hrs when i bought it new.now it has 105hrs on it.an it has worked 6 months hauling an feeding hay.no probs with it what so ever.
/ servicing the 7040 #2
I think you should also be changing out the hydraulic fluid and filters + front axle fluids. I think these were supposed to be changed at 50 hrs according to the manual.
Dave M7040
well we just quickly changed the oil after we hayed the cows.thats next on the list.
/ servicing the 7040 #4
Doing a service on the M is more involved than the GL or MX, but I'm sure you've done harder ones. We lost a lot of fluid when my son did ours on the M8540 and will be better prepared next time.
/ servicing the 7040 #5
When not changing the hydraulic oil also, I have finally settled on the process of draining the hydraulic oil "clean catch" into a 66 quart Sterilite container. Then after the filter change, I pump it back in with a GoatThroat pump. Risk of contamination is very low. If you are trying to quick change the filters, having a spare set of magnets to install beforehand into the replacement filters will make the switch faster (and you can make sure that you clean them well because you are not rushing to get it done.).
/ servicing the 7040 #6
If not changing hyd oil insert a shop vac nozzle in hyd oil filler hole and when shop vac is running very little oil will be lost while changing hyd filters.
/ servicing the 7040 #7
Yeah, we learned we were not quite quick enough to skip draining or vacuum.
/ servicing the 7040 #8
I think it poor engineering on Kubota's part for needing to drain hyd oil or use means such as shop vacuum in order just to change hyd filters. I've owned and repaired other tractor brands that one can change hyd filters and only loose VERY LITTLE hyd oil. IMHO this is very important if one is in the FIELD away from any shop and hyd filter requires changing.
my brother changed the oil on the 7040.an he learned something he didnt know.i had told him where my sockets was for the 7040.he goes i got my wrenches i wont need no sockets.but he found out he needed sockets to change the oil.
2016 VOLVO DD25B DOUBLE DRUM ROLLER (A65053)
2016 VOLVO DD25B...
Single Cedar Glider (A65583)
Single Cedar...
1999 JOHN DEERE 344H WHEEL LOADER (A63276)
1999 JOHN DEERE...
White Oak Boards (A65640)
White Oak Boards...
1966 Hale Livestock Trailer (A66285)
1966 Hale...
2021 KENWORTH T680 6X4 T/A  SLEEPER TRUCK TRACTOR (A59914)
2021 KENWORTH T680...
